Hi All,
I have created a custom drop down menu plugin with required web items(links), what i need is to have a drop down on one of the web item(which is on the parent drop down menu) which links to required url.
Any suggestion is much appreciated!
Hey Sharath,
Refer to the document here and see if "Programmatically showing or hiding a dropdown" would do it for you.
