Submitting a JIRA form via Clone++ (a plugin) generates a stack trace...
DocMagic October 24, 2012
Currently, we incorporate two plugins to achieve the desired issue management results we need. One is the Customware Connector for Salesforce/JIRA integration. The other is Clone++, a tool used for clone a JIRA issue and moving the new issue to another project. Both plugins are installed and configured. At this point, though, if we attempt to clone a JIRA issue, we receive a stacktrace which I will include below. We can bypass this stacktrace by removing three fields. Those fields are custom fields that are used by the connector.
* Salesforce.com Case
* Salesforce.com User
* Case Attachments
The error we witness follow. Can you help? Thanks!!
Oops - an error has occurred
System Error
A system error has occurred.
Please try submitting this problem via the Support Request Page
Otherwise, please create a support issue on our support system at http://support.atlassian.com with the following information:
a description of your problem
cut & paste the error and system information found below
attach the application server log file ( /opt/jira_data/log/atlassian-jira.log )
Cause:
java.lang.NumberFormatException: For input string: 10823_text
Stack Trace: hide
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:48)
at java.lang.Long.parseLong(Long.java:419)
at java.lang.Long.(Long.java:678)
at com.atlassian.jira.issue.customfields.CustomFieldUtils.getCustomFieldId(CustomFieldUtils.java:109)
at com.atlassian.jira.issue.managers.DefaultCustomFieldManager.getCustomFieldObject(DefaultCustomFieldManager.java:339)
at com.atlassian.jira.issue.fields.DefaultFieldManager.isCustomField(DefaultFieldManager.java:659)
at com.atlassian.jira.issue.fields.DefaultFieldManager.getOrderableField(DefaultFieldManager.java:752)
at sun.reflect.GeneratedMethodAccessor638.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.atlassian.multitenant.impl.MultiTenantComponentFactoryImpl$AbstractMultiTenantAwareInvocationHandler.invokeInternal(MultiTenantComponentFactoryImpl.java:181)
at com.atlassian.multitenant.impl.MultiTenantComponentFactoryImpl$MultiTenantAwareInvocationHandler.invoke(MultiTenantComponentFactoryImpl.java:211)
at $Proxy486.getOrderableField(Unknown Source)
at com.atlassian.plugin.osgi.hostcomponents.impl.DefaultComponentRegistrar$ContextClassLoaderSettingInvocationHandler.invoke(DefaultComponentRegistrar.java:129)
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:154)
at org.swift.jira.web.action.issue.ClonePlusDetails.handleFields(ClonePlusDetails.java:1297)
at org.swift.jira.web.action.issue.ClonePlusDetails.doValidation(ClonePlusDetails.java:861)
at webwork.action.ActionSupport.validate(ActionSupport.java:391)
at webwork.action.ActionSupport.execute(ActionSupport.java:162)
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:82)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39)
at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31)
at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:205)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:143)
at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:152)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:78)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:104)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:88)
at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77)
at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:157)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71)
at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:350)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:75)
at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
at com.sysbliss.jira.plugins.workflow.servlet.JWDSendRedirectFilter.doFilter(JWDSendRedirectFilter.java:25)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
at com.atlassian.jira.web.monitor.ActiveRequestsFilter$PassToChainFilterFunc.doFilter(ActiveRequestsFilter.java:346)
at com.atlassian.jira.web.monitor.ActiveRequestsFilter$DebugLogFilterFunc.doFilter(ActiveRequestsFilter.java:463)
at com.atlassian.jira.web.monitor.ActiveRequestsFilter.doFilter(ActiveRequestsFilter.java:173)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:75)
at com.atlassian.multitenant.servlet.MultiTenantServletFilter.doFilter(MultiTenantServletFilter.java:91)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:554)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:776)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:705)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:898)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
at java.lang.Thread.run(Thread.java:662)
Referer URL: https://projects.docmagic.com/secure/ClonePlusDetails!default.jspa
Build Information:
Uptime : N/A
Version : 5.0.1
Build Number : 721
Build Date : Thu Mar 15 00:00:00 PDT 2012
Build Revision : 838c4a0b95816e00f959efadbfe32a2139ca3829
Atlassian Partner : null
Installation Type : Standalone
Server ID : BM6K-T277-OA9Q-6WBJ
Last Upgrade : 26/Mar/12 06:00 PM (v5.0#713)
Server Information:
Application Server: Apache Tomcat/6.0.32
Servlet Version: 2.5
File Paths:
Location of entityengine.xml: file:/opt/atlassian-jira-5.0.1-standalone/atlassian-jira/WEB-INF/classes/entityengine.xml
Location of atlassian-jira.log: /opt/jira_data/log/atlassian-jira.log
Memory Information:
Total Memory: 682 MB
Free Memory: 398 MB
Used Memory: 284 MB
Total PermGen Memory: 256 MB
Free PermGen Memory: 61 MB
Used PermGen Memory: 194 MB
System Information:
System Date : Wednesday, 24 Oct 2012
System Time : 16:41:57 -0700
Current Working Directory : /
Java Version : 1.6.0_29
Java Vendor : Sun Microsystems Inc.
JVM Version : 1.0
JVM Vendor : Sun Microsystems Inc.
JVM Implementation Version : 20.4-b02
Java Runtime : Java(TM) SE Runtime Environment
Java VM : Java HotSpot(TM) 64-Bit Server VM
User Name : jira
User Timezone : America/Los_Angeles
User Locale : English (United States)
System Encoding : ISO-8859-1
Operating System : Linux 2.6.18-308.1.1.el5
OS Architecture : amd64
Application Server Container :
Database type : mysql
Database JNDI address : mysql jdbc:mysql://localhost:3306/jiradb?useUnicode=true&characterEncoding=utf8&sessionVariables=storage_engine=InnoDB
Database URL : Hidden
Database version : 5.0.95
Database driver : MySQL-AB JDBC Driver mysql-connector-java-5.1.10 ( Revision: ${svn.Revision} )
External user management : OFF
JVM Input Arguments : -Djava.util.logging.config.file=/opt/jira/conf/logging.properties -XX:MaxPermSize=256m -Xms256m -Xmx768m -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -XX:+PrintGCDateStamps -Djira.home=/opt/jira_data -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.endorsed.dirs=/opt/jira/endorsed -Dcatalina.base=/opt/jira -Dcatalina.home=/opt/jira -Djava.io.tmpdir=/opt/jira/temp
Language Info:
Installed languages: English (UK)
French (France)
German (Germany)
Japanese (Japan)
Spanish (Spain)
Default language: English (United States) - System Default
Request Information:
- Request URL: https://projects.docmagic.com/500page.jsp
- Scheme: https
- Server: projects.docmagic.com
- Port: 443
- URI: /500page.jsp
- Context Path:
- - Servlet Path: /500page.jsp
- - Path Info: null
- - Query String:
Request Attributes
- javax.servlet.forward.request_uri : /secure/ClonePlusDetails.jspa
- javax.servlet.forward.context_path :
- javax.servlet.forward.servlet_path : /secure/ClonePlusDetails.jspa
- javax.servlet.forward.path_info : /500page.jsp
- os_securityfilter_already_filtered : true
- com.atlassian.jira.web.filters.JiraPostEncodingFilter_alreadyfiltered : true
- jira.session.max.inactive.interval : 18000
- jira.request.time.micros : 0
- com.newrelic.agent.TRANSACTION_NAME : /*.jspa
- atlassian.core.seraph.original.url : /secure/ClonePlusDetails.jspa
- javax.servlet.error.servlet_name : action
- javax.servlet.request.key_size : 256
- com.atlassian.jira.web.filters.JiraFirstFilter_alreadyfiltered : true
- com.atlassian.gzipfilter.GzipFilter_already_filtered : true
- loginfilter.already.filtered : true
- com.atlassian.johnson.filters.JohnsonFilter_already_filtered : true
- jira.webwork.generic.dispatcher : webwork.dispatcher.GenericDispatcher@2b91bc6c
- com.atlassian.jira.web.filters.JiraLastFilter_alreadyfiltered : true
- gzipMimeTypes : text/.*,application/x-javascript,application/javascript,application/xml,application/xhtml +xml
- com.atlassian.jira.web.filters.accesslog.AccessLogFilter_already_filtered : true
- javax.servlet.request.ssl_session : A47113F6562A825C16078390D941896369581D03D74CDEFB35D719CAE004C2A8
- javax.servlet.error.message :
- jira.session.last.accessed.time : 1351122109764
- webwork.result : Value stack =========== ===========
- jira.request.username : colin
- javax.servlet.request.cipher_suite : DHE-RSA-AES256-SHA
- javax.servlet.error.request_uri : /secure/ClonePlusDetails.jspa
- com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter_already_filtered : true
- com.atlassian.seraph.auth.LoginReason : OK
- jira.webwork.cleanup : false
- jira.request.id : 1001x20066x1
- javax.servlet.error.status_code : 500
- jira.request.start.millis : 1351122117083
- com.atlassian.jira.web.filters.accesslog.AccessLogRequestInfoexit.called : true
- com.atlassian.core.filters.HeaderSanitisingFilter_already_filtered : true
- jira.request.assession.id : kmbx2j
- com.atlassian.gzipfilter.org.tuckey.web.filters.urlrewrite.RuleMatched : true
- javax.servlet.error.exception : javax.servlet.ServletException: java.lang.NumberFormatException: For input string: 10823_text
Request Logging
0 log statements generated by this request:
Listeners
- Issue Assignment Listener (com.atlassian.jira.event.listeners.history.IssueAssignHistoryListener)
- Issue Index Listener (com.atlassian.jira.event.listeners.search.IssueIndexListener)
- Mail Listener (com.atlassian.jira.event.listeners.mail.MailListener)
Services
- Backup Service (com.atlassian.jira.service.services.export.ExportService)
- Delay: 720 minutes
- USE_DEFAULT_DIRECTORY: true
- Help Desk Issue Email Service (com.atlassian.jira.service.services.mail.MailFetcherService)
- Delay: 1 minutes
- popserver: Help Desk Issues
- handler.params: project=helpdesk, issuetype=1, stripquotes=true, reporterusername=admin, ccassignee=false, ccwatcher=true
- forwardEmail: helpdesk@docmagic.com
- handler: Create a new issue or add a comment to an existing issue
- Mail Queue Service (com.atlassian.jira.service.services.mail.MailQueueService)
- Delay: 1 minutes
- NotificationCacheUpdateJob-job (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- Delay: 1440 minutes
- pluginJobName: NotificationCacheUpdateJob-job
- repeatInterval: 86400000
- initiallyFired: true
- PluginLicenseExpiryJob-job (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- pluginJobName: PluginLicenseExpiryJob-job
- Service Provider Token Remover (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- Delay: 480 minutes
- pluginJobName: Service Provider Token Remover
- repeatInterval: 28800000
- Subversion Revision Indexing Service (com.atlassian.jira.plugin.ext.subversion.revisions.RevisionIndexService)
- Delay: 1 minutes
- com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- Delay: 1 minutes
- pluginJobName: com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job
- repeatInterval: 60000
- com.atlassian.streams.internal.ActivityProviderConnectionMonitorImpl:activityProviderMonitor (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- Delay: 5 minutes
- pluginJobName: com.atlassian.streams.internal.ActivityProviderConnectionMonitorImpl:activityProviderMonitor
- repeatInterval: 300000
- net.customware.plugins.connector.core.scheduler.LicenseSchedulerImpl (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- Delay: 5 minutes
- pluginJobName: net.customware.plugins.connector.core.scheduler.LicenseSchedulerImpl
Plugins
- ActiveObjects Plugin - OSGi Bundle 0.19.7 - Plugin by Atlassian
- Enabled
- Admin Menu Sections 1.0 - Plugin by Atlassian
- Enabled
- Apache HttpClient OSGi bundle 4.0 - Plugin by Apache Software Foundation
- Enabled
- Apache HttpCore OSGi bundle 4.0 - Plugin by Apache Software Foundation
- Enabled
- Applinks Product Plugin 3.6.4 - Plugin by Atlassian
- Enabled
- build: 10
- Atlassian Embedded Crowd - Administration Plugin 1.3.7 - Plugin by Atlassian
- Enabled
- Atlassian Gadgets OAuth Service Provider Plugin 3.1.21 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Admin Quick Navigation 5.0.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Admin Summary Component 5.0.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Application Properties 5.0.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Closure Template Renderer 5.0.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Common AppLinks Based Issue Link Plugin 5.0.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian JIRA - Plugins - Confluence Link 5.0.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian JIRA - Plugins - Gadgets Plugin 5.0.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Issue Web Link 5.0.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian JIRA - Plugins - Look And Feel Logo Upload Plugin 5.0.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Mail Plugin 5.0.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian JIRA - Plugins - OAuth Consumer SPI 5.0.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - OAuth Service Provider SPI 5.0.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Project Config Plugin 5.0.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Quick Edit Plugin 1.0.36 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - REST Plugin 5.0.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Remote JIRA Link 5.0.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian JIRA - Plugins - SAL Plugin 5.0.1 - Plugin by Atlassian Software Systems
- Enabled
- Atlassian JIRA - Plugins - Share Content Component 5.0.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - View Issue Panels 5.0.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian OAuth Admin Plugin 1.3.10 - Plugin by Atlassian
- Enabled
- Atlassian OAuth Consumer Plugin 1.3.10 - Plugin by Atlassian
- Enabled
- Atlassian OAuth Consumer SPI 1.3.10 - Plugin by Atlassian
- Enabled
- Atlassian OAuth Service Provider Plugin 1.3.10 - Plugin by Atlassian
- Enabled
- Atlassian OAuth Service Provider SPI 1.3.10 - Plugin by Atlassian
- Enabled
- Atlassian REST - Module Types 2.5.5.1 - Plugin by Atlassian
- Enabled
- Atlassian Soy Templates - Plugin 1.0.0-m3 - Plugin by Atlassian
- Enabled
- Atlassian Template Renderer API 1.3.1 - Plugin by Atlassian
- Enabled
- Atlassian Template Renderer Velocity 1.6 Plugin 1.3.1 - Plugin by Atlassian
- Enabled
- Atlassian UI Plugin 3.5.5 - Plugin by Atlassian
- Enabled
- Atlassian Universal Plugin Manager - Plugin License Storage plugin 2.3 - Plugin by Atlassian Pty Ltd
- Enabled
- Atlassian Universal Plugin Manager Plugin 2.1 - Plugin by Atlassian Pty Ltd
- Enabled
- Bob Swift Software - JIRA Clone Plus Plugin 2.0.0 - Plugin by Bob Swift Software, LLC
- Enabled
- post.upgrade.url: /plugins/servlet/org.swift.jira.clone-plus-plugin/post-install
- post.install.url: /plugins/servlet/org.swift.jira.clone-plus-plugin/post-install
- configure.url: /plugins/servlet/org.swift.jira.clone-plus-plugin/license
- plugin-banner: images/clone-plus-plugin-banner.png
- plugin-icon: images/clone-plus-plugin-16x16.png
- plugin-logo: images/clone-plus-plugin-72x72.png
- atlassian-licensing-enabled: true
- Content Link Resolvers Plugin 1.0 - Plugin by Atlassian
- Enabled
- Crowd REST API 1.0 - Plugin by Atlassian Software Systems
- Enabled
- Enabled
- Crowd System Password Encoders 1.0 - Plugin by Atlassian Software Systems
- Enabled
- Custom Field Types & Searchers 1.0 - Plugin by Atlassian
- Enabled
- CustomWare Core Connector Plugin 1.2.2 - Plugin by CustomWare
- Enabled
- configure.url: /plugins/servlet/customware/connector/config.action
- CustomWare JIRA Connector Plugin 1.2.2 - Plugin by CustomWare
- Enabled
- CustomWare Salesforce.com Connector Plugin 5.2.1 - Plugin by CustomWare
- Enabled
- Embedded Gadgets Plugin 3.1.21 - Plugin by Atlassian
- Enabled
- English (United Kingdom) Language Pack 5.0.1 - Plugin by Atlassian
- Enabled
- English (United States) Language Pack 5.0.1 - Plugin by Atlassian
- Enabled
- FishEye Plugin 5.0.7 - Plugin by Atlassian Software Systems
- Enabled
- French (France) Language Pack 5.0.1-rc1-v2r1732-2012-03-13 - Plugin by Atlassian Community
- Enabled
- Gadget Dashboard Plugin 3.1.21 - Plugin by Atlassian
- Enabled
- Gadget Directory Plugin 3.1.21 - Plugin by Atlassian
- Enabled
- Gadget Spec Publisher Plugin 3.1.21 - Plugin by Atlassian
- Enabled
- German (Germany) Language Pack 5.0.1-rc1-v2r4572-2012-03-13 - Plugin by Atlassian Community
- Enabled
- ICU4J 3.8.0.1 - Plugin by Atlassian Pty Ltd
- Enabled
- Issue Operations Plugin 1.0 - Plugin by Atlassian
- Enabled
- Issue Tab Panels Plugin 1.0 - Plugin by Atlassian
- Enabled
- Issue Views Plugin 1.0 - Plugin by Atlassian
- Enabled
- JDOM DOM Processor 1.0.0 - Plugin by SpringSource
- Enabled
- JIRA Active Objects SPI implementation 0.19.7 - Plugin by Atlassian Software Systems
- Enabled
- JIRA Activity Stream Plugin 5.1.0 - Plugin by Atlassian
- Enabled
- JIRA Bamboo Plugin 5.1.6 - Plugin by Atlassian Software Systems Pty Ltd
- Enabled
- configure.url: /secure/admin/jira/ViewBambooApplicationLinks.jspa
- JIRA Component Watcher 2.3.0 - Plugin by (unknown)
- Enabled
- JIRA Feedback Plugin 1.1.6 - Plugin by Atlassian
- Enabled
- JIRA Footer 1.0 - Plugin by Atlassian
- Enabled
- JIRA Importers Plugin (JIM) 4.4 - Plugin by Atlassian
- Enabled
- JIRA JSON-RPC Plugin 1.0.4 - Plugin by Atlassian Software
- Enabled
- JIRA Linker Plugin 1.4.0 - Plugin by Atlassian Pty Ltd
- Enabled
- JIRA Streams Inline Actions Plugin 5.1.0 - Plugin by Atlassian Software Systems Pty Ltd
- Enabled
- JIRA Subversion plugin 0.10.9.1 - Plugin by Atlassian Pty Ltd
- Enabled
- JIRA Usage Hints 1.0 - Plugin by Atlassian
- Enabled
- JIRA Watcher Field 2.5.3 - Plugin by (unknown)
- Enabled
- JIRA Welcome Plugin 1.1.6 - Plugin by Atlassian
- Enabled
- JIRA iCalendar Plugin 1.0.9 - Plugin by Atlassian
- Enabled
- JQL Functions 1.0 - Plugin by Atlassian
- Enabled
- JSON Library 20070829.0.0.1 - Plugin by Atlassian Pty Ltd
- Enabled
- Japanese (Japan) Language Pack 5.0.1-rc1-v2r10394-2012-03-07 - Plugin by Atlassian Community
- Enabled
- Keyboard Shortcuts Plugin 1.0 - Plugin by Atlassian
- Enabled
- Neko HTML 1.9.12.1 - Plugin by Atlassian Pty Ltd
- Enabled
- Opensocial Plugin 3.1.21 - Plugin by Atlassian
- Enabled
- Preset Filters Sections 1.0 - Plugin by Atlassian
- Enabled
- Project Panels Plugin 1.0 - Plugin by Atlassian
- Enabled
- Project Role Actors Plugin 1.0 - Plugin by Atlassian
- Enabled
- ROME, RSS and atOM utilitiEs for Java 1.0 - Plugin by Sun Microsystems
- Enabled
- ROME: RSS/Atom syndication and publishing tools 0.9.0 - Plugin by SpringSource
- Enabled
- RPC JIRA Plugin 5.0.5 - Plugin by Atlassian
- Enabled
- Renderer Component Factories Plugin 1.0 - Plugin by Atlassian
- Enabled
- Renderer Plugin 1.0 - Plugin by Atlassian
- Enabled
- Reports Plugin 1.0 - Plugin by Atlassian
- Enabled
- Spanish (Spain) Language Pack 5.0.1-rc1-v2r7218-2012-03-13 - Plugin by Atlassian Community
- Enabled
- Streams API 5.1.0 - Plugin by Atlassian
- Enabled
- Streams Core Plugin 5.1.0 - Plugin by Atlassian Software Systems Pty Ltd
- Enabled
- Streams Inline Actions Plugin 5.1.0 - Plugin by Atlassian Software Systems Pty Ltd
- Enabled
- Streams Plugin 5.1.0 - Plugin by Atlassian Software Systems Pty Ltd
- Enabled
- Streams SPI 5.1.0 - Plugin by Atlassian
- Enabled
- Streams Third Party Provider Plugin 5.1.0 - Plugin by Atlassian
- Enabled
- Support Tools Plugin 2.9.5 - Plugin by Atlassian Support
- Enabled
- Top Navigation Bar 1.0 - Plugin by Atlassian
- Enabled
- User Format 1.0 - Plugin by Atlassian
- Enabled
- User Navigation Bar Sections 1.0 - Plugin by Atlassian
- Enabled
- User Profile Links 1.0 - Plugin by Atlassian
- Enabled
- User Profile Panels 1.0 - Plugin by Atlassian
- Enabled
- View Project Operations Sections 1.0 - Plugin by Atlassian
- Enabled
- Web Resources Plugin 1.0 - Plugin by Atlassian
- Enabled
- Webwork Plugin 1.0 - Plugin by Atlassian
- Enabled
- Wiki Renderer Macros Plugin 1.0 - Plugin by Atlassian
- Enabled
- Workflow Designer Plugin 2.5.4 - Plugin by Atlassian
- Enabled
- Workflow Plugin 1.0 - Plugin by Atlassian
- Enabled
Bob Swift
October 24, 2012
Please open an issue at https://bobswift.atlassian.net/browse/JCPP with the version numbers for JIRA and the other plugins. It would also help to indicate the type of the custom fields you suspect as causing the problem.
