[Server based version, latest version]
My team is small (below 20..)
and Project is not complex.
We have already used Gantt chart with Excel.
check1. Visual UI is very important .. Easy look,
- Weekly display should be clear it. (we control the project based on week)
- dependency line and other line should be simple and clear
check2. Many function is not important. Easy Usage is more important
- Project will be limited as one or two
- Currently Project will be controlled separately,
but I am not sure in the future
Would you suggest Gantt plugin?
There are several different Gantt app that I believe would meet your needs. I would suggest BigGantt. The great thing about apps is that you can try them out and see which one meets your needs. Check out the Gantt apps here: https://marketplace.atlassian.com/search?product=jira&query=gantt
Thank you for your reply.
I am little worry about it.
How can I say... Um.. (English is not my mother language.)
I want to listen the real user experience.
A few information is confused for me.
It seems advertisement or real pure information.
Anyway It is true your reply is so helpful.
My recommendation was based on real user experience. I have used BigGantt for over 8 years. Once again I would suggest installing the app and testing it out to see if it meets your needs.
