Sum custom field using jql in groovy script
Dave Paulson December 8, 2016
I'm trying to sum a custom field through a jql query result using a groovy script, but I get a null pointer order. Can anyone be of help? My code is as follows:
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.issue.search.SearchException
import com.atlassian.jira.web.bean.PagerFilter
def jqlSearch = "project = TISFOLIO"
//If you are going to use a JIRA version => 7 then you should get the ApplicationUser instead of User, to do that remove the .directoryUser
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def searchService = ComponentAccessor.getComponentOfType(SearchService.class)
SearchService.ParseResult parseResult = searchService.parseQuery(user, jqlSearch)
def value = 0
def myCustomField = customFieldManager.getCustomFieldObjectByName("customfield_13312")
if (parseResult.isValid()) {
try {
def results = searchService.search(user, parseResult.getQuery(), PagerFilter.getUnlimitedFilter())
def issues = results.getIssues()
issues.each {
if (it.getCustomFieldValue(myCustomField))
value += (double) it.getCustomFieldValue(myCustomField)
} catch (SearchException e) {
e.printStackTrace()
} else {
log.warn("Invalid query")
return null
return value
Vasiliy Zverev
December 8, 2016
I am not sure what namely caused NullPointerExeption, usually it happens when there is no value for caustom field. I add hull check and refactored your code:
SearchService.ParseResult parseResult = searchService.parseQuery(user, "project = TISFOLIO")
double value = 0
    try {
        CustomField myCustomField = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("customfield_13312")
                .getIssues().each {
                    if (it.getCustomFieldValue(myCustomField) != null) //
        e.printStackTrace()
} else {
    return null
return value
