When using the SumUp Two Dimentional Statistics Gadget I do get incorrect sorting in one of the dimensions (see below). Works fine in Jira's generic gadget. Any known work around?
If Decadis is "on the line", any solution?
The field in question is just a regular Select List (single choice):
Best Regards
Bo
Hi @Bo Bøgvald ,
have you already tried to update the order by clicking on Risk Impact in the first line of your table?
Cheers
Thorsten
No I have not... I didn't knew... Thanks for making me aware. It even stay sorted next time I use the gadget.
I would still like to see the table sorted from the start, maybe even to be able to specify the sort order in the gadget, like you can do in the native Jira gadget. But that's another story.
