I would like to find out if Jira 6.4.1 support Java JRE 8 Update 141. Our security team wants to update due to vulnerabilities found. Our current versio is 131.
Thanks for any help or pointers!
ByronDouglas
Hi Thomas,
here you can find the system requirements for Jira 6.4:
https://confluence.atlassian.com/jira064/supported-platforms-720411857.html
All requirements are covered here for Jira 6.4:
As far as they are conserned only:
"There is a known issue with Java 1.8.0_25 and 1.8.0_31", meaning it should be fine with the higher releases.
Thanks! We upgraded to 144 without any issues.
