Switch from ondemand to local hosted
Francisco Silva July 11, 2016
Hi!
I need to import the version of the data in the cloud for a hosted version, follow the documentation provided by Atlassian and did not work.
Atlassian documentation used :
https://confluence.atlassian.com/adminjiraserver071/migrating-from-jira-cloud-to-server-applications-802592270.html
when I use the restore option received the following message
You are attempting to import data from JIRA 1000.141.1 which is a more recent version than this version. Some features that you may have used before will not be available in this version of JIRA. Click here to acknowledge this error and proceed anyway.
when I use the import projeto received the following message
This data appears to be from an older version of JIRA. Please upgrade the data and try again. The current version of JIRA is at build number '71013', but the supplied backup file was for build number '100004'.
Timothy
July 11, 2016
You should be able to import the latest version of data (the full backup) by clicking the "Click here" link.
