Sync JIRA fields and csv
Oleksii Okhmush
There are 2 columns in csv file, stored on Google Drive. 1st - domain name 2nd - priority
1 customfield, like "domain name" text, single-line
Are  there any way, when task is created to check data from customfiled, compare from 1st column in csv and take priority from 2nd column back to ticket in JIRA?
Mohamed Benziane
Hi @Oleksii Okhmush
I don't have your answer but i can give you an idea, why don't you set a customfield of type select list (cascading), parent would be domain name and child priority ?  And you can have your value in jira in parent and child in once by importing them from a csv.
Sorry for my bad english.
Regards
Oleksii Okhmush
This is a good idea, but i have about 1500+ domain names and this list is updating from another service. ITs impossbile to keep such information actual in customfield.
Mohamed Benziane
Hum i see, i will let some other people of the community to answer you but you can also take a look at the NFEED addon, it will populate select list from a database or csv automaticcaly, so for example you can let the other service populate the database.
Regards
Register now
