Synching JIRA Issue Field with Confluence
Phillip Yero
Is there a way to sync a JIRA issue field with a table in Confluence?
Specifically, is there a way to have the Status of a JIRA issue be displayed in a table in Confluence and, when that status is changed, have the change be reflected in the table?
Nic Brough -Adaptavist-
January 21, 2016
Have you tried the JIRA macro?  It lets you define lists of JIRA issues (or just one) and displays their fields in confluence, with the current content.
Fabrizio Galletti
January 21, 2016
the only limit (as far asi know) if you have a big confluence table and you need to add more then one JIRA field you can't do that or you can:
  • add a JIRA macro for every cell
  • select to view only one value
This solution has some problems:
  • page load
  • jura issue macro will always show "table title"
Get Certified! ✍️
