Synchronize versions between projects
Camille Lecerf
How could I sycnhronize versions between 2 projects please ? Or copy them from one to another ?
ps : I have scriptrunner so if you want to share your script with me I would be grateful to you.
Camille
3 accepted
3 votes
Stefaan Quackels
December 21, 2017 edited
You can actually also rely on a synchronizer plugin such as Exalate. This plugin would allow to keep synchronized versions (and issues under it) between two different projects.
Let me know if you need any additional help figuring this out.
Alexey Matveev
December 21, 2017
In ScriptRunner your script would look something like this
import com.atlassian.jira.project.Project
import com.atlassian.jira.project.version.Version
def projectManager = ComponentAccessor.getProjectManager()
def projectSource = projectManager.getProjectObjByKey("SOURCE_PROJECT_KEY") // change project name here
def projectDestination = projectManager.getProjectObjByKey("DESTINATION_PROJECT_KEY") // change project name here
def versionManager = ComponentAccessor.getVersionManager()
List<Project> projectList = new ArrayList<>();
projectList.add(projectSource)
Collection<String> versionList = versionManager.getAllVersionsForProjects(projectList, false).stream().map{it.getName()}.collect()
for (version in versionList) {
log.debug("Now adding version " + version + " to " + projectDestination.name)
versionManager.createVersion(version, new Date(), new Date() + 7, "New version description", projectDestination.id, null)
You need to add logic how to handle already existing versions.
Verhás István
August 8, 2018
Hi @Alexey Matveev,
Good job. I have enhanced it a little, not to loose any metadata of versions
Collection<Version> versionList = versionManager.getAllVersionsForProjects(projectList, false)
versionManager.createVersion(version.name, version.startDate, version.releaseDate, version.description, projectDestination.id,null, version.released)
The existing version logic is still missing.
Sarath January 15, 2019
how to modify the code where if the version in the source project has word 'abc' then it should be created in project a, if the version in the source has word 'xyz' then it should be created in project b?
Verhás István
January 15, 2019
Hi @Sarath,
You have to define two destination projects, projectDestinationA and projectDestinationB. In the last line of createVersion you need an 'if' to select the proper project to create the version in.
Be warned that you have only specified only two cases of four ones. Missing the case when both abc and xyz can be found in the source version, and the other missing case when none of them is there.
Istvan
Like • Sarath likes this
Sarath January 18, 2019
Thank you @Verhás István. I modified in this way:
def projectSource = projectManager.getProjectObjByKey("KEY") // change project name here
def projectDestination1 = projectManager.getProjectObjByKey("KEY1") // change project name here
def projectDestination2 = projectManager.getProjectObjByKey("KEY2") // change project name here
def projectDestination3 = projectManager.getProjectObjByKey("KEY3") // change project name here
def versionname = version.getName()
if (versionname.length() >= 3 && versionname.substring(0, 3).equalsIgnoreCase("abc")) {
log.debug("Now adding version " + version + " to " + projectDestination1.name)
versionManager.createVersion(version.name, version.startDate, version.releaseDate, version.description, projectDestination1.id,null, version.released)
} else if (versionname.length() >= 10 && versionname.substring(0, 10).equalsIgnoreCase("def")) {
log.debug("Now adding version " + version + " to " + projectDestination2.name)
versionManager.createVersion(version.name, version.startDate, version.releaseDate, version.description, projectDestination2.id,null, version.released)
} else if (versionname.length() >= 7 && versionname.substring(0, 7).equalsIgnoreCase("ghi")) {
log.debug("Now adding version " + version + " to " + projectDestination3.name)
versionManager.createVersion(version.name, version.startDate, version.releaseDate, version.description, projectDestination3.id,null, version.released)
} else {
//do nothing
My question is, how I need to load it as a custom listener?
Steps I followed to create the file:
1. Select ""Custom listener"
2. ProjectKey: Selected both source and destination projects
3. Events: I'm not sure what to select, I selected generic one "projectupdatedEvent"
4. Used the above inline code.
Though there are no errors in the code it wasn't copying the version names.
Verhás István
January 18, 2019 edited
Hi @Sarath,
The modification seems to be perfect. Actually, this script is intended to be used in script runner terminal window, not as a listener. This script is able to synchronize the existing versions, while the listener approach targets the versions to be created in the future.
As it is mentioned above please visit the documentation of the Version Listener at https://scriptrunner.adaptavist.com/latest/jira/listeners.html#_version_synchroniser_listener .
Istvan
Tarun Sapra
Script runner has built in script for it (in Script listener section)
Version synchroniser
Synchronises versions across multiple projects
Out of the box it's not supported in JIRA
https://jira.atlassian.com/browse/JRASERVER-2698?focusedCommentId=1691393&page=com.atlassian.jira.plugin.system.issuetabpanels%3Acomment-tabpanel#comment-1691393
Tarun Sapra
from the docs
Please understand the functionality of the listener before implementing it in your production environment. The listener propagates the following:
  1. version creates to all target projects, when a version is created in the source project"
Tarun Sapra
And if you want to use groovy script in the script console to copy the version via a script then it can be easily achieved using VersionManager
https://docs.atlassian.com/DAC/javadoc/jira/7.1.0-m01/reference/com/atlassian/jira/project/version/VersionManager.html
You can get all Versions for specific project and then create versions for desired projects.
Like • wajih zouaoui likes this
Camille Lecerf
Thank you @Tarun Sapra for your great help ! I am going to use the script listener "Version synchroniser"
Thank you also @Alexey Matveev and @Stefaan Quackels for your help
Fede Espinoza June 26, 2019 edited
Jira CLI has `copyVersion` and `copyVersions` options.
https://bobswift.atlassian.net/wiki/spaces/JCLI/pages/6684679/Reference#Reference-copyVersion
copyVersion : Copy a version from one project to the same project or another project.
copyVersions : Copy all versions from one project to another project.
e.g. jira.sh --action copyVersions --project "zjiracli" --toProject "zjiracliC" --replace
Register now
