Tasks not in Version Summary
Tobias Hofer December 11, 2012
How can I show tasks in the version summary of a project? I only see bugs, improvements, etc..
onkeldom
December 11, 2012
Hi!
First things that came to my mind, just wrote them down:
  1. Tasks are not part of the used Issue Type Scheme (which would also prevent you from creating them in the first place).
  2. There are Restrictions (like Security Levels) used for those tasks and you're not allowed to see them.
  3. The tasks don't have a fix-version and are not shown in the version summary (normal behavior)
  4. There are no tasks in the project
Have you checked every point of the above already?
Dom
Hmm I found it. Version has to be entered by "Fix Version/s" "Affects Version" Is not enough. Can you tell me why? Thanks so far
Vishnukumar Vasudevan
You may check the field configuration used for Taks in that project. Fix Versions might have been disabled in this.
Register now
