Hi Everyone,
Is there a method/report available to filter, Billable work hours down to 3 levels; Project wise, User wise, Task to monitor Planned vs Actual?
Ex-
Project name
User1
Task 1
Task2
User2
Task1
thanks,
Randika
Hi @Randika Palipane ,
You can group by Epic in Planned vs Actual Report, however, I think the view you are looking for is actually in the Logged Time Report. You can add the columns Planned time, Billable time, and Logged time to your report, and then group by those 3 parameters- Project, User, Task.
You can click the top of the Billable column to sort to see the ones with billable time at the top. Alternatively, if you are using Billable Accounts, then you can filter by those Accounts.
Here's what it could look like. Make sure you enable the extra columns to show up:
Thank you very much! this helps my purpose.
