Tempo Timesheet - Show filter
Karrie Dash
I've updated Tempo Timesheet to 9.1.2. In our previous version, each user could display issues based on a filter. Example, all ticket with a type of "Time" would display, whether or not the user had entered time for that period.
The new version doesn't seem to do that anymore. It only shows issues that time has been logged by that user.
Does anyone know how to tell Timesheet which tickets to show based off a filter in the new version?
deborah duffy August 19, 2019
Susanne, one cannot simply remove features. Was there no impact study?
Also, the link provided above to drag and drop is restricted. Can you provide me access please? Users are experiencing a UI lockup when they attempt to do this.
Susanne Götz _Tempo_
January 9, 2019
Hi Karrie,
You are correct, this functionality was removed in Tempo 9.0 in the My Work,  Timesheet view.
It is possible to add filters to the sidebar of the My Work, Calendar view. You can then use the drag and drop functionality to create worklogs (https://tempo-io.atlassian.net/wiki/spaces/THC/pages/292716680/To+configure+the+issue+suggestions+sidebar+in+Tempo+Timesheets+for+Server).
Susanne Götz
Tempo team
Rich Scire
At Grainger, we use the filter feature extensively. It is extremely unfortunate that you've removed the feature. I am using the favorite feature in the issue search box but that is significantly less user friendly. I'm getting a lot of complaints about this from managers who want to enforce a minimum level of standardization for the issues reported on.
