Tempo Timesheets for JIRA - Installation Failure
Breno August 4, 2017
While installing the Tempo Timesheets for JIRA add on on JIRA Cloud, I'm getting below error.
"O host do complemento retornou o código de resposta HTTP 400 quando tentamos contatá-lo durante a instalação. Tente novamente mais tarde ou entre em contato com o fornecedor do complemento."
How to fix this issue?
somethingblue
August 10, 2017
Hi Breno,
Are you still getting this error?  If so can you provide your Cloud URL and I can check with the Cloud team to see if there is an issue with your instance.
Branden
Breno August 11, 2017
No. Now I have successfully installed the plugin.
Thank you.
