Hi Chris,
The original idea was to classify accounts into types. That is how we have used them at TM Software. We have different categories like "Service Agreement", "Fixed Contract", "Training", etc. This allows us to report on different types of engaments.
You use case is quite different as you want to classify each worklog in the same account. This makes the account category relation unsuitable to you. Instead, you can add a dynamic worklog attribute with the possible values for each worklog.
We are thinking about how to solve this better and maybe we can extend the categories to be more flexible, or add a new "work type" classification on a worklog level.
Thanks for the feedback and I hope the dynamic worklog attribute feature solves your use case until we have a better solution.
Viðar
TEMPO
Hi Mike,
Thanks for your contact. Contractspro Cloud does not have integration with Tempo. It has its own time tracking system. We are working on New features to be released soon. You can check the roadmap on mindproapps.com/roadmap.
Eduardo
This is exactly what i have done, i have set up the account in as attribute in the worklog for the relevant project. That will do for now.
Thank you for the quick reply
