Tempo excel export with custom fields
Andrew Guliver
is it possible for tempo plugin to include issue custom fields in excel exports? I did not find such option. Thank you
3 votes
Susanne Götz [Tempo]
January 13, 2014
Hi Andrew,
you can add JIRA custom fields to the excel export. This is done in Administration-> Add-ons, Tempo, Fields.
In the Custom Field section you can check which JIRA custom field you want to have included in the report.
Kind regards
Susanne
Andrew Guliver
Saved my day, thank you
Otto Kalliomäki May 16, 2016
You also saved my ass laugh !
Uhub Admin September 19, 2016
Hi Susanne,
While this looks to work, this now causes another issue as a global setting. We support many teams, each with their own unique requirements. The option to add custom fields should be on a report by report basis.
Craig
Like 4 people like this
Sakshi Mittal April 18, 2018
You saved my day too!
Lisa Schaffer
Thanks Susanne!
Works perfectly!
Allen Steele May 15, 2018
  1. Open Jira Cloud.
  2. Click Switch App icon (3 stacked lines).
  3. Select Tempo - My Work.
  4. Click Settings (gear icon)
  5. Click Custom Fields.
  6. Key press F5 (refresh) to show a list of Jira fields to export in Tempo Reports.
  7. Click the box next to each custom field.
  8. Click Save.
Piotr Czernik
January 3, 2019
It is available. Change Filter by: User, Group by 1. Worklog, and then choose List View. On the same list (List View) at the bottom you should see the custom field that you enabled in options previously.
Vanessa Castro
I couldn't see the custom fields- can you advise?
stolyarovdevelopment
October 23, 2017
is this accurate for JIRA cloud? I have looked everywhere but can't find how to add custom fields from JIRA to tempo report or export.
please help
Michael (Admin)
November 30, 2017
Me too! Is that availabel in the cloud version?!
Register now
