I have na issue (a test - TST-1658) related to a another issue but it appears done when is in Progress.
What should i do?
As far as I can see in your screenshot, you ve got two issues connected to the current one. The first one is in the "In Progress" status, the other one in the Closed status. If you mean, why the TST-1658 is crossed out, it means that the Resolution field is set for this issue. Set the resolution field to Unresolved.
