Alternatively, you can create an issue within Jira and add your text/links to the Description field of an issue. Once you do this, create a filter based on the newly created issue
ex:
issue = "ABC-1"
Next, go to your dashboard and add a Filter Results gadget and select your newly created filter based. For the section Columns to display, select only Description and save.
You should now see your text/links.
Javier A.
thanks Javier. your solution although a hack, works. much appreciated.
Thank you for the alternative solution
Samanth,
In regards to your question, that is really up to a personal preference. The Text Gadget is disabled by default because it is a potential security risk, as it can contain arbitrary HTML which could potentially make your JIRA system vulnerable to XSS attacks as stated in our documentation Adding the Text Gadget.
That being said, the risk can really depends on your usage. If you are running on a local network only and you trust your users to not abuse the gadget, then it should be okay to be used in your JIRA.
Again, this is something that you'll have to weigh the pros and cons about. There are a few listings in our marketplace for Rich Text add-ons, that might be worth taking a look at to see if they are able to replace the functionality in the Text Gadget.
In JIRA Cloud we've removed the Text Gadget to avoid any potential security risks and suggest users look into the Rich Text Gadget on our Marketplace.
I hope this helps answer your question Samanth.
- Josh Loe
the Atlassian "Rich Text Gadget for Jira" doesn't appear work for Jira Cloud. It installs ok, but isn't visible under the available gadgets.
What about the server version? Are there any secure alternatives to the Text Gadget?
@joshloe, is there another option to the Rich Text Gadget now that this gadget appears to no longer be found in the Marketplace?
As of December 2024, the Rich Text Gadget (from Atlassian Labs) is available on the Atlassian Marketplace - I just installed it in a Jira Cloud instance, with no issues.
We actually use Extended Dashboards for Jira to be able to workaround this limitation by Jira. It comes with other useful gadgets aswell.
