In my custom fields, I was able to inject parameters from *.properties file using the getVelocityParameters method, and later use them in my *.vm files.
How could we do it in a custom field searcher? There is no getVelocityParameters method!
Happens in the CustomFieldRenderer class. Create your own renderer by extending this and use that in the searcher.
Works very well, thank you!
