The following plugins are required by JIRA, but have not been started
Deleted user April 19, 2014
The following plugins fail to load:
Gadget Directory Plugin (com.atlassian.gadgets.directory)
Atlassian Navigation Links Plugin (com.atlassian.plugins.atlassian-nav-links-plugin)
Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
It is a newly installed instance of JIRA. I configured the database connection to mysql and set up a user. Then I started the server with the start-jira.sh. I am using a ubuntu vserver.
Logfile: Log
What I have tried so far:
  • Removed the .lock file
  • Used Java 6 instead of 7
  • Restarted
  • Added the JVM parameter -Datlassian.plugins.enable.wait=500
  • Increased memory to 1024m for min AND max
  • Increased Permsize to 512m
  • Cleared the work folder in installation dir
  • Removed the '.osgi-plugins' and the '.bundled-plugins' folders
  • Reinstalled
Observations:
  • plugins seem to load till the last 5-10 ones
    • then timeout messages appear, but i dont know why
  • every plugin gets managed to load while the 2000 Timer is running
    • the last ones still get an TIMER error in the log files
Jen Connor
Setting the -Datlassian.plugins.enable.wait=300 argument as explained in the link Fabio gave resolved this issue for me. It takes about 10 minutes for Jira to start up now, but at least it is able to start all of the plugins.
Fabio Racobaldo _Catworkx_
Perfect! I'm happy for that
Deleted user April 27, 2014
As described in the question this doesn't help me. I set the wait timer to 5000 but this still doesn't help.
Michael Brinson June 10, 2014
I'm in exactly the same boat Stephan.
I've got pretty nearly identical specs as you also:
Ubuntu 12.04.4 LTS
And I've tried all of the same resolutions as well with no change in results.
I end up with the same 3 plugins failing to load as well.
Did you ever get this resolved?
Andrea Bodei September 4, 2015
What is the procedure to set -Datlassian.plugins.enable.wait=300 ?
Dave Woods January 19, 2017
Setting the timeout worked for me.  In my Win 7 box, just added it to setenv.bat.  Also I had to open permissions to the  C:\Program Files (x86)\Atlassian folder to allow the lock file to be created
Hello Stephan,
please take a look here https://confluence.atlassian.com/display/JIRAKB/JIRA+System+Plugin+Timeout+While+Waiting+for+Plugins+to+Enable
It's seems a timeout issue.
Let me know,
Fabio
Deleted user April 21, 2014
java -Djava.io.tmpdir=./ -jar support-tools.jar
Benchmark: RandomAccessFile
TOTALS
statavgmedianminmax
open76.60942.00327.04217.291.035
r/w31.05627.32717.613249.342
close8.4377.6754.81895.907
delete94.41039.48928.38316.871.992
All times are in nanoseconds.
This results seem to be good or excellent. It's not the disk drive speed.
lscpu
Architecture: i686
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
Vendor ID: AuthenticAMD
CPU family: 16
Model: 2
Stepping: 3
CPU MHz: 750.000
BogoMIPS: 3817.64
Virtualization: AMD-V
Should'nt be the CPU either.
lshw -short -C memory
H/W path Device Class Description
/0/0 memory 2GiB System memory
/0/1/0 memory 128KiB L1 cache
/0/1/1 memory 512KiB L2 cache
Memory should be fine too.
Am I missing something?
whereisaaron May 3, 2014
Installing 6.2.4 on a stock CentOS 6 on an AWS c3.large instance I had the same problem. The first time I started it about 30 plugins timed out, the second restart only these three. I changed the plugin timer to 600 and that allow Jira to start.
Aaron - When you say you changed the plugin timer, are you just talking about the -Datlassian.plugins.enable.wait=300 argument, or do you mean you somehow went into the settings for each plugin and added the :=600 option to the plugin?
whereisaaron June 10, 2014
Michael - I changed just that one global setting to a larger value rather than any per-plugin settings.
Page not found
I have the same problem with a x86-64bit dual-core 16GB RAM under Linux Ubuntu 15.04 (kernel 4.0.9). I hope to don't have to reinstall JIRA again.
Daniel Wester
April 20, 2014
What are the specs of the machine you're running on? I've seen this issue on a small amazon vm and bumping up the CPU helped there.
Deleted user April 20, 2014
It is a linux vserver with Ubuntu 12.04.4 LTS.
Maxx-RAM is 2GB.
Guaranteed RAM is 1GB.
Maybe i should take more guaranteed RAM.
What is the smallest amount Jira and JVM need?
lscpu
Architecture: i686
CPU(s): 4
CPU family: 16
Model: 2
Stepping: 3
CPU MHz: 750.000
BogoMIPS: 3817.64
Hello Stephan,
take a look here in order to fix your problem https://confluence.atlassian.com/display/JIRAKB/JIRA+does+not+Start+Due+to+Disabled+Bundled+Plugin
If not, please provide me more information about the log.
Hope this helps,
Fabio
SELECT * FROM pluginstate where pluginenabled = 'false';
gets me an empty dataset, so the plugins are enabled.
any error on the log file?
