  • Community
  • Q&A
  • Jira
  • Questions
  • • The maximum memory allocation pool (-Xmx) is set to 786m but still not starti g up the JIRA
Devendar Gangapuram
September 27, 2022
Hi Team,
Today , I have upgraded my Java to jre1.8.0_341 , since then, JIRA is not starting up. So as per the logs, I had to set my "maximum memory allocation pool (-Xmx)" to 786m but still it is not starting. Could you guys please let me know how to over come this issue. If I set to 512m , JIRA is staring for a while and giving the below error. But after set it to 786m, its not at all starting.
Pramodh M
Hi @Devendar Gangapuram
Find this configuration file in Installation Directory /opt/atlassian/jira/bin/setenv.sh
In case of Linux
JVM_MINIMUM_MEMORY="384m"
JVM_MAXIMUM_MEMORY="2048m"
Finally
JAVA_OPTS="-Xms${JVM_MINIMUM_MEMORY} -Xmx${JVM_MAXIMUM_MEMORY} ${JVM_CODE_CACHE_ARGS} ${JAVA_OPTS} ${JVM_REQUIRED_ARGS} ${DISABLE_NOTIFICATIONS} ${JVM_SUPPORT_RECOMMENDED_ARGS} ${JVM_EXTRA_ARGS} ${JIRA_HOME_MINUSD} ${START_JIRA_JAVA_OPTS}"
In case of Windows
Find this configuration file in Installation Directory C:\Program Files\Atlassian\Jira\bin\setenv.bat
set JVM_MINIMUM_MEMORY=384m
set JVM_MAXIMUM_MEMORY=2048m
Finally
set JAVA_OPTS=%JAVA_OPTS% -Xms%JVM_MINIMUM_MEMORY% -Xmx%JVM_MAXIMUM_MEMORY% %JVM_CODE_CACHE_ARGS% %JVM_REQUIRED_ARGS% %DISABLE_NOTIFICATIONS% %JVM_SUPPORT_RECOMMENDED_ARGS% %JVM_EXTRA_ARGS% %JIRA_HOME_MINUSD% %START_JIRA_JAVA_OPTS%
Find the above section and make the changes to the JVM_MAXIMUM_MEMORY to 1024m and check once?
Pramodh
Devendar Gangapuram
September 28, 2022
Thanks @Pramodh M ,
I have already tetsed with 1024m and 786m but no luck.  Please let me know for which value it works. Randoamly I am trying to modiy the value but still not working.
