×I have created Select Custom custom field by programmatically and added default text searcher but the operator '=' is not working.
Text searcher won't support = operator. Use the Contains (~) operator instead.
Text search does not support the = operator. It's also the wrong searcher to use for a select list type field.
You could try an "exact text searcher" instead if your field really is text - there are a couple of add-ons that provide one of those. Or s a select list searcher if it's really a list of options.
Ok, I will try this. Thanks.
I have another question is that which searcher can be used for Select list and multi-select list?
The select searcher.
