The problem does not rest API call from a chrome frame
한우람 August 27, 2012
Jira after installing the Chrome Frame, and the problem does not operate normally slower Rest API call can not access. Please check it
Infinite Loading in Project's People page
Network Capture...
Rest API call failed
Request Information
No Response
Dave C
August 28, 2012
I raised a Fug for this under JRA-29528 as Chrome Frame rocks, and it would be great if we fully supported it. As it's not within our Supported Platforms, please don't hold your breath on it getting fixed; it would be great if it did though!
Nic Brough -Adaptavist-
August 27, 2012
There doesn't seem to be a question here. You've given us some screenshots and suggested some sort of network failure, but not really described the problem.
If the problem is a network issue, then you need to debug your networks.
If the problem is a Jira issue, then you need to describe what it is, and look at your log files to see if there are errors or related warnings in there, and maybe try turning the logging levels up
You also say something about "installing chrome frame" - maybe you should explain that, or remove it and try the system from a supported browser, plain, to see if that works ok.
한우람 August 28, 2012
It's not network problem. If I use chrome browser, it work fine.
Just When I use chrome frame, I can't add project member.
Harry Chan
August 28, 2012
It's an issue with Chrome Frame. It's not supported.
Register here ⬇️
