The problem to install(x86) : org.apache.jasper.JasperException: java.lang.NullPointerException
Deleted user May 25, 2014
Hi
I have problem to install 64bit..
I installed the JIRA but there is error below..
I don't know why I have this problem.
I tried this even though it is not the problem about NullPointerException.
however it was useless
https://confluence.atlassian.com/display/JIRAKB/'org.apache.jasper.JasperException+Unable+to+compile+class+for+JSP'+or+Workflow+Actions+Inaccessible
Is there somebody to solve this problem..??
help me...
64bit
JIRA 6.2.5
port : 8000
CelsoA
June 2, 2014
Hi Hyeonoh Ji,
Which Java version are you using on this machine?
Also, is it Linux or Windows?
Please paste here the error message so more people can help with this issue.
Celso Yoshioka
Nic Brough -Adaptavist-
May 25, 2014
Null pointer exception is the Java fallback error message effectively - it really means something bad has happened, not been caught by the code, not been anticipated and it could be caused by anything. You've probably just picked on the first error message you found on the web without reading all the other errors that lead up to it.
However, that "anything" is almost certainly logged as well. What does the rest of the log say?
