Hello everyone!
Please help us. Recently, we have encountered a situation where our Jira Server is crashing and we have to restart it.
In the Thread dump, we can see that the problem is most likely related to the class EagerLoadingOfBizCustomFieldPersister and its methods, but we can't figure out exactly what is causing the issue.
Jira Server ver. 7.3.3
Thread Stack
http-nio-8080-exec-50
at java.lang.Long.valueOf(J)Ljava/lang/Long; (Long.java:840)
at org.ofbiz.core.entity.jdbc.SqlJdbcUtil.getValue(Ljava/sql/ResultSet;ILorg/ofbiz/core/entity/model/ModelField;Lorg/ofbiz/core/entity/GenericEntity;Lorg/ofbiz/core/entity/model/ModelFieldTypeReader;)V (SqlJdbcUtil.java:647)
at org.ofbiz.core.entity.EntityListIterator.currentGenericValue()Lorg/ofbiz/core/entity/GenericValue; (EntityListIterator.java:169)
at org.ofbiz.core.entity.EntityListIterator.next()Lorg/ofbiz/core/entity/GenericValue; (EntityListIterator.java:246)
at org.ofbiz.core.entity.EntityListIterator.getCompleteList()Ljava/util/List; (EntityListIterator.java:308)
at org.ofbiz.core.entity.GenericDAO.selectByAnd(Lorg/ofbiz/core/entity/model/ModelEntity;Ljava/util/Map;Ljava/util/List;)Ljava/util/List; (GenericDAO.java:731)
at org.ofbiz.core.entity.GenericHelperDAO.findByAnd(Lorg/ofbiz/core/entity/model/ModelEntity;Ljava/util/Map;Ljava/util/List;)Ljava/util/List; (GenericHelperDAO.java:150)
at org.ofbiz.core.entity.GenericDelegator.findByAnd(Lorg/ofbiz/core/entity/model/ModelEntity;Ljava/util/Map;Ljava/util/List;)Ljava/util/List; (GenericDelegator.java:903)
at org.ofbiz.core.entity.GenericDelegator.findByAnd(Ljava/lang/String;Ljava/util/Map;Ljava/util/List;)Ljava/util/List; (GenericDelegator.java:881)
at org.ofbiz.core.entity.GenericDelegator.findByAnd(Ljava/lang/String;Ljava/util/Map;)Ljava/util/List; (GenericDelegator.java:850)
at com.atlassian.jira.ofbiz.DefaultOfBizDelegator.findByAnd(Ljava/lang/String;Ljava/util/Map;)Ljava/util/List; (DefaultOfBizDelegator.java:83)
at com.atlassian.jira.ofbiz.WrappingOfBizDelegator.findByAnd(Ljava/lang/String;Ljava/util/Map;)Ljava/util/List; (WrappingOfBizDelegator.java:62)
at com.atlassian.jira.issue.customfields.persistence.EagerLoadingOfBizCustomFieldPersister.getValuesForIssueId(Ljava/lang/Long;)Ljava/util/List; (EagerLoadingOfBizCustomFieldPersister.java:97)
at com.atlassian.jira.issue.customfields.persistence.EagerLoadingOfBizCustomFieldPersister.getValuesForTypeAndParent(Lcom/atlassian/jira/issue/fields/CustomField;Ljava/lang/Long;Ljava/lang/String;)Ljava/util/List; (EagerLoadingOfBizCustomFieldPersister.java:76)
at com.atlassian.jira.issue.customfields.persistence.OfBizCustomFieldValuePersister.getValues(Lcom/atlassian/jira/issue/fields/CustomField;Ljava/lang/Long;Lcom/atlassian/jira/issue/customfields/persistence/PersistenceFieldType;Ljava/lang/String;)Ljava/util/List; (OfBizCustomFieldValuePersister.java:61)
at com.atlassian.jira.issue.customfields.impl.CascadingSelectCFType.getOptionValueForParentId(Lcom/atlassian/jira/issue/fields/CustomField;Ljava/lang/String;Lcom/atlassian/jira/issue/Issue;)Lcom/atlassian/jira/issue/customfields/option/Option; (CascadingSelectCFType.java:430)
at com.atlassian.jira.issue.customfields.impl.CascadingSelectCFType.getValueFromIssue(Lcom/atlassian/jira/issue/fields/CustomField;Lcom/atlassian/jira/issue/Issue;)Ljava/util/Map; (CascadingSelectCFType.java:280)
at com.atlassian.jira.issue.customfields.impl.CascadingSelectCFType.getValueFromIssue(Lcom/atlassian/jira/issue/fields/CustomField;Lcom/atlassian/jira/issue/Issue;)Ljava/lang/Object; (CascadingSelectCFType.java:76)
at com.atlassian.jira.issue.fields.ImmutableCustomField.getValue(Lcom/atlassian/jira/issue/Issue;)Ljava/lang/Object; (ImmutableCustomField.java:349)
at com.atlassian.jira.issue.DocumentIssueImpl.getCustomFieldValue(Lcom/atlassian/jira/issue/fields/CustomField;)Ljava/lang/Object; (DocumentIssueImpl.java:326)
at com.atlassian.jira.issue.fields.ImmutableCustomField.getRendererCustomFieldValue(Lcom/atlassian/jira/issue/fields/layout/field/FieldLayoutItem;Lcom/atlassian/jira/issue/Issue;Ljava/util/Map;)Ljava/lang/Object; (ImmutableCustomField.java:837)
at com.atlassian.jira.issue.fields.ImmutableCustomField.getColumnViewHtml(Lcom/atlassian/jira/issue/fields/layout/field/FieldLayoutItem;Ljava/util/Map;Lcom/atlassian/jira/issue/Issue;)Ljava/lang/String; (ImmutableCustomField.java:832)
at com.atlassian.jira.issue.fields.layout.column.ColumnLayoutItemImpl.getHtml(Ljava/util/Map;Lcom/atlassian/jira/issue/Issue;)Ljava/lang/String; (ColumnLayoutItemImpl.java:106)
at sun.reflect.GeneratedMethodAccessor551.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object; (Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object; (DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object; (Method.java:498)
at org.apache.velocity.util.introspection.UberspectImpl$VelMethodImpl.doInvoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object; (UberspectImpl.java:385)
at org.apache.velocity.util.introspection.UberspectImpl$VelMethodImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object; (UberspectImpl.java:374)
at com.atlassian.velocity.htmlsafe.introspection.AnnotationBoxingMethod.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object; (AnnotationBoxingMethod.java:26)
at com.atlassian.velocity.htmlsafe.introspection.UnboxingMethod.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object; (UnboxingMethod.java:30)
at org.apache.velocity.runtime.parser.node.ASTMethod.execute(Ljava/lang/Object;Lorg/apache/velocity/context/InternalContextAdapter;)Ljava/lang/Object; (ASTMethod.java:270)
at org.apache.velocity.runtime.parser.node.ASTReference.execute(Ljava/lang/Object;Lorg/apache/velocity/context/InternalContextAdapter;)Ljava/lang/Object; (ASTReference.java:262)
at org.apache.velocity.runtime.parser.node.ASTReference.value(Lorg/apache/velocity/context/InternalContextAdapter;)Ljava/lang/Object; (ASTReference.java:507)
at org.apache.velocity.runtime.parser.node.ASTExpression.value(Lorg/apache/velocity/context/InternalContextAdapter;)Ljava/lang/Object; (ASTExpression.java:71)
at org.apache.velocity.runtime.parser.node.ASTSetDirective.render(Lorg/apache/velocity/context/InternalContextAdapter;Ljava/io/Writer;)Z (ASTSetDirective.java:142)
at org.apache.velocity.runtime.parser.node.ASTBlock.render(Lorg/apache/velocity/context/InternalContextAdapter;Ljava/io/Writer;)Z (ASTBlock.java:72)
at org.apache.velocity.runtime.directive.Foreach.performIteration(Ljava/util/Iterator;Lorg/apache/velocity/runtime/parser/node/Node;Lorg/apache/velocity/context/InternalContextAdapter;Ljava/io/Writer;)V (Foreach.java:393)
at org.apache.velocity.runtime.directive.Foreach.render(Lorg/apache/velocity/context/InternalContextAdapter;Ljava/io/Writer;Lorg/apache/velocity/runtime/parser/node/Node;)Z (Foreach.java:316)
at org.apache.velocity.runtime.parser.node.ASTDirective.render(Lorg/apache/velocity/context/InternalContextAdapter;Ljava/io/Writer;)Z (ASTDirective.java:175)
at org.apache.velocity.runtime.directive.VelocimacroProxy.render(Lorg/apache/velocity/context/InternalContextAdapter;Ljava/io/Writer;Lorg/apache/velocity/runtime/parser/node/Node;)Z (VelocimacroProxy.java:212)
at org.apache.velocity.runtime.directive.RuntimeMacro.render(Lorg/apache/velocity/context/InternalContextAdapter;Ljava/io/Writer;Lorg/apache/velocity/runtime/parser/node/Node;)Z (RuntimeMacro.java:247)
at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(Lorg/apache/velocity/context/InternalContextAdapter;Ljava/io/Writer;)Z (ASTIfStatement.java:87)
at org.apache.velocity.runtime.parser.node.SimpleNode.render(Lorg/apache/velocity/context/InternalContextAdapter;Ljava/io/Writer;)Z (SimpleNode.java:336)
at org.apache.velocity.Template.merge(Lorg/apache/velocity/context/Context;Ljava/io/Writer;Ljava/util/List;)V (Template.java:328)
at org.apache.velocity.Template.merge(Lorg/apache/velocity/context/Context;Ljava/io/Writer;)V (Template.java:235)
at org.apache.velocity.app.VelocityEngine.mergeTemplate(Ljava/lang/String;Ljava/lang/String;Lorg/apache/velocity/context/Context;Ljava/io/Writer;)Z (VelocityEngine.java:381)
at com.atlassian.velocity.DefaultVelocityManager.writeEncodedBodyImpl(Ljava/io/Writer;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Lorg/apache/velocity/context/Context;)V (DefaultVelocityManager.java:117)
at com.atlassian.velocity.DefaultVelocityManager.writeEncodedBody(Ljava/io/Writer;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Lorg/apache/velocity/context/Context;)V (DefaultVelocityManager.java:97)
at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.toWriterImpl(Ljava/io/Writer;Z)V (DefaultVelocityTemplatingEngine.java:122)
at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.asHtml(Ljava/io/Writer;)V (DefaultVelocityTemplatingEngine.java:113)
at com.atlassian.jira.web.component.AbstractWebComponent.asHtml(Ljava/io/Writer;Ljava/lang/String;Ljava/util/Map;)V (AbstractWebComponent.java:44)
at com.atlassian.jira.web.component.IssueTableWebComponent$1.write(Lcom/atlassian/jira/issue/Issue;)V (IssueTableWebComponent.java:160)
at com.atlassian.jira.issue.views.util.DefaultSearchRequestViewBodyWriterUtil$2.writeIssue(Lcom/atlassian/jira/issue/Issue;Ljava/io/Writer;)V (DefaultSearchRequestViewBodyWriterUtil.java:61)
at com.atlassian.jira.issue.views.util.IssueWriterHitCollector.collect(Lorg/apache/lucene/document/Document;)V (IssueWriterHitCollector.java:26)
at com.atlassian.jira.issue.statistics.util.DocumentHitCollector.collect(I)V (DocumentHitCollector.java:30)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.searchAndSort(Lcom/atlassian/query/Query;Lcom/atlassian/jira/user/ApplicationUser;Lorg/apache/lucene/search/Collector;Lcom/atlassian/jira/web/bean/PagerFilter;Z)V (LuceneSearchProvider.java:349)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.searchAndSort(Lcom/atlassian/query/Query;Lcom/atlassian/jira/user/ApplicationUser;Lorg/apache/lucene/search/Collector;Lcom/atlassian/jira/web/bean/PagerFilter;)V (LuceneSearchProvider.java:140)
at com.atlassian.jira.issue.views.util.DefaultSearchRequestViewBodyWriterUtil.searchAndSort(Lcom/atlassian/jira/issue/search/SearchRequest;Lorg/apache/lucene/search/Collector;Lcom/atlassian/jira/web/bean/PagerFilter;)V (DefaultSearchRequestViewBodyWriterUtil.java:73)
at com.atlassian.jira.issue.views.util.DefaultSearchRequestViewBodyWriterUtil.writeTableBody(Ljava/io/Writer;Lcom/atlassian/jira/web/component/IssueTableWriter;Lcom/atlassian/jira/issue/search/SearchRequest;Lcom/atlassian/jira/web/bean/PagerFilter;)V (DefaultSearchRequestViewBodyWriterUtil.java:65)
at com.atlassian.jira.issue.views.AbstractSearchRequestExcelView.writeSearchResults(Lcom/atlassian/jira/issue/search/SearchRequest;Lcom/atlassian/jira/plugin/searchrequestview/SearchRequestParams;Ljava/io/Writer;)V (AbstractSearchRequestExcelView.java:80)
at com.atlassian.jira.plugin.searchrequestview.DefaultSearchRequestURLHandler.handleRequest(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V (DefaultSearchRequestURLHandler.java:372)
at com.atlassian.jira.web.servlet.SearchRequestViewServlet.doGet(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V (SearchRequestViewServlet.java:25)
at javax.servlet.http.HttpServlet.service(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V (HttpServlet.java:622)
at javax.servlet.http.HttpServlet.service(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (ApplicationFilterChain.java:230)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (ApplicationFilterChain.java:165)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (ApplicationFilterChain.java:192)
at com.atlassian.jira.web.filters.JiraLastFilter.lambda$doFilter$0(Lcom/atlassian/jira/servermetrics/ServerMetricsDetailCollector;Ljavax/servlet/FilterChain;Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (JiraLastFilter.java:39)
at com.atlassian.jira.web.filters.JiraLastFilter$$Lambda$988.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (Unknown Source)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (ChainedFilterStepRunner.java:74)
at com.atlassian.jira.web.filters.JiraLastFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (JiraLastFilter.java:36)
at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (XContentTypeOptionsNoSniffFilter.java:20)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (AbstractHttpFilter.java:32)
at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (HeaderSanitisingFilter.java:37)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (IteratingFilterChain.java:39)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (DelegatingPluginFilter.java:58)
at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (IncludeResourcesFilter.java:77)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (DelegatingPluginFilter.java:64)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (IteratingFilterChain.java:37)
at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (IncludeResourcesFilter.java:38)
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (ContextFilter.java:24)
at com.atlassian.servicedesk.internal.web.ExternalCustomerLockoutFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (ExternalCustomerLockoutFilter.java:56)
at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (ServingRequestsFilter.java:37)
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (RedirectInterceptingFilter.java:21)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (PrettyUrlsSiteMeshFixupFilter.java:32)
at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (PrettyUrlsDispatcherFilter.java:55)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (PrettyUrlsSiteMeshFilter.java:79)
at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (PrettyUrlsMatcherFilter.java:51)
at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (BotKillerFilter.java:36)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (ServletFilterModuleContainerFilter.java:70)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (ServletFilterModuleContainerFilter.java:58)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (AccessLogFilter.java:92)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (AccessLogFilter.java:78)
at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (XsrfTokenAdditionRequestFilter.java:46)
at com.atlassian.jira.web.filters.pagebuilder.PageBuilderFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (PageBuilderFilter.java:81)
at com.atlassian.jira.web.filters.CommittedResponseHtmlErrorRecoveryFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (CommittedResponseHtmlErrorRecoveryFilter.java:55)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (PrettyUrlsCombinedMatchDispatcherFilter.java:56)
at com.atlassian.jira.web.filters.MauEventFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (MauEventFilter.java:49)
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(Lcom/atlassian/jira/servermetrics/ServerMetricsDetailCollector;Ljavax/servlet/FilterChain;Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (JiraSecurityFilter.java:80)
at com.atlassian.jira.security.JiraSecurityFilter$$Lambda$810.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (Unknown Source)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (SecurityFilter.java:242)
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (JiraSecurityFilter.java:78)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (TrustedApplicationsFilter.java:103)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (BaseLoginFilter.java:148)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (JiraLoginFilter.java:77)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (OAuthFilter.java:79)
at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (ProfilingFilter.java:99)
at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (JIRAProfilingFilter.java:16)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (AbstractJohnsonFilter.java:59)
at com.atlassian.jira.web.filters.johnson.JiraJohnson503Filter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (JiraJohnson503Filter.java:24)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V (RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)Z (UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (UrlRewriteFilter.java:394)
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (CorrelationIdPopulatorFilter.java:30)
at com.atlassian.jira.plugin.issuenav.LegacyTextQueryUrlRedirectFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (LegacyTextQueryUrlRedirectFilter.java:39)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.lambda$invokeFilterChain$0(Ljavax/servlet/FilterChain;Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)Lcom/atlassian/servicedesk/internal/web/CustomerContextSettingFilter$ExceptionCapture; (CustomerContextSettingFilter.java:181)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter$$Lambda$578.call()Ljava/lang/Object; (Unknown Source)
at com.atlassian.servicedesk.internal.utils.context.ReentrantThreadLocalBasedCodeContext.rteInvoke(ZZLcom/atlassian/servicedesk/api/customer/NoExceptionsCallable;)Ljava/lang/Object; (ReentrantThreadLocalBasedCodeContext.java:139)
at com.atlassian.servicedesk.internal.utils.context.ReentrantThreadLocalBasedCodeContext.runOutOfContext(Lcom/atlassian/servicedesk/api/customer/NoExceptionsCallable;)Ljava/lang/Object; (ReentrantThreadLocalBasedCodeContext.java:92)
at com.atlassian.servicedesk.internal.utils.context.CustomerContextServiceImpl.runOutOfCustomerContext(Lcom/atlassian/servicedesk/api/customer/NoExceptionsCallable;)Ljava/lang/Object; (CustomerContextServiceImpl.java:64)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.outOfCustomerContext(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (CustomerContextSettingFilter.java:174)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilterImpl(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (CustomerContextSettingFilter.java:130)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (CustomerContextSettingFilter.java:121)
at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (JwtAuthFilter.java:32)
at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (JiraAnalyticsFilter.java:42)
at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (AbstractHttpFilter.java:39)
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (LocationCleanerFilter.java:36)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (AbstractCachingFilter.java:31)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (AbstractEncodingFilter.java:39)
at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (PathMatchingEncodingFilter.java:41)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (JiraStartupChecklistFilter.java:72)
at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (MultipartBoundaryCheckFilter.java:36)
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (MetricsCollectorFilter.java:25)
at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (JiraFirstFilter.java:59)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (GzipFilter.java:115)
at com.atlassian.gzipfilter.GzipFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (GzipFilter.java:92)
at com.atlassian.jira.web.filters.gzip.JiraGzipFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V (JiraGzipFilter.java:44)
at com.atlassian.jira.web.filters.InstantUpgradeHoldingFilter.doFilter(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljavax/servlet/FilterChain;)V (InstantUpgradeHoldingFilter.java:99)
at org.apache.catalina.core.StandardWrapperValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V (StandardWrapperValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V (StandardContextValve.java:108)
at org.apache.catalina.core.StandardHostValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V (StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V (ErrorReportValve.java:79)
at org.apache.catalina.core.StandardEngineValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V (StandardEngineValve.java:87)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(Lorg/apache/catalina/connector/Request;Lorg/apache/catalina/connector/Response;)V (AbstractAccessLogValve.java:620)
at org.apache.catalina.connector.CoyoteAdapter.service(Lorg/apache/coyote/Request;Lorg/apache/coyote/Response;)V (CoyoteAdapter.java:349)
at org.apache.coyote.http11.Http11Processor.service(Lorg/apache/tomcat/util/net/SocketWrapperBase;)Lorg/apache/tomcat/util/net/AbstractEndpoint$Handler$SocketState; (Http11Processor.java:784)
at org.apache.coyote.AbstractProcessorLight.process(Lorg/apache/tomcat/util/net/SocketWrapperBase;Lorg/apache/tomcat/util/net/SocketEvent;)Lorg/apache/tomcat/util/net/AbstractEndpoint$Handler$SocketState; (AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(Lorg/apache/tomcat/util/net/SocketWrapperBase;Lorg/apache/tomcat/util/net/SocketEvent;)Lorg/apache/tomcat/util/net/AbstractEndpoint$Handler$SocketState; (AbstractProtocol.java:802)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun()V (NioEndpoint.java:1410)
at org.apache.tomcat.util.net.SocketProcessorBase.run()V (SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V (ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run()V (ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run()V (TaskThread.java:61)
at java.lang.Thread.run()V (Thread.java:745)
