Time custom field question
Rumceisz
Hi All,
I created a scripted field which results the time in a particular status for each issue.
The endusers will export the report to excel which contains this custom field value. The problem is that this field - according to the time spent in that status - contains '2d 1h' or '3w 4d 4m' values and they need every value only in minutes because of the excel.
How can we do that?
Thanks in advance!
Rumi
Florin Manaila
October 28, 2012
You need to specify a separate template for the excel view in your atlassian-plugin.xml and use it to format the time in minutes only.
<resource type="velocity" name="excel" location="mytemplate.vm"/>
Rumceisz
the excel export will be generated from Issue Navigator. Can I implement this script to a scripted field?
Florin Manaila
October 28, 2012
The excel view will be used whenever you custom field will be used in an "export to excel" action regardless of what/where it was triggered from.
I'm not sure I understand what you mean by scripted field. I thought you meant you wrote the plugin for the custom field yourself, in which case the above solution is correct. However, if you use a third party plugin you need to clarify this with the developer.
Rumceisz
ok,
sorry:)
the current custom field which results the time spent in the particular status is a scripted field I made.
The field will be displayed in the issue navigator and the results (about 300 issues) will be exported to excel.
The users who need these custom field ask for displaying these time values in 'Minutes' in order to easily compare in the excel report.
So I think there is nothing to do with excel: can the script be altered to display the time spent in minutes?
here is the code:
import com.atlassian.core.util.DateUtils
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.history.ChangeItemBean
def componentManager = ComponentManager.getInstance()
def changeHistoryManager = componentManager.getChangeHistoryManager()
def inProgressName = "Clarification"
def rt = [0]
changeHistoryManager.getChangeItemsForField (issue, "status").reverse().each {ChangeItemBean item ->
    def timeDiff = System.currentTimeMillis() - item.created.getTime()
    if (item.fromString == inProgressName) {
        rt << -timeDiff
    if (item.toString == inProgressName){
        rt << timeDiff
// NOTE: doesn't show anything if less than 60 seconds
DateUtils.getDurationString(Math.round(rt.sum() / 1000))
Florin Manaila
October 28, 2012
Oh, the Scripted Field from the groovy plugin(?). Then you have no option but to always return the time in minutes.
JamieA
October 28, 2012
I'm not quite sure that's the case. You can use a custom template, and in that you can tell whether it's being rendered for excel or not, and do the conversion to pretty as necessary. Don't have a fully worked example though/
Rumceisz
Hi Florin,
yes, this is a groovy script which works great. The only wish is to show the time spent value in minutes. But I'm out of idea...:(
Florin Manaila
October 29, 2012
Just replace
with
Math.round(rt.sum() / 60000)
Rumceisz
Hi Florin,
I get result but also a warning message after the code replace:
"The indexer for this field expects a java.lang.String but the script returned a java.lang.Long - this will cause problems."
Florin Manaila
October 29, 2012
Replace with
new String(Math.round(rt.sum() / 60000))
Rumceisz
Hi Florin,
I insterted:
and it resulted:
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script21.groovy: 23: unable to resolve class string @ line 23, column 1. new string(Math.round(rt.sum() / 60000)) ^ 1 error A stacktrace has been logged.
JamieA
October 29, 2012
You did "new string", not "new String". See the error message.
JamieA
October 30, 2012
OK, use:
Math.round(rt.sum() / 60000).toString()
Rumceisz
You1re right, I corrected but it didn't work as well:
javax.script.ScriptException: groovy.lang.GroovyRuntimeException: Could not find matching constructor for: java.lang.String(java.lang.Long) A stacktrace has been logged.
Rumceisz
Perfect!
thank you
Sleep well Jamie
Maxim Abramovich
Where you render field representaion? In script or in velocity template? If in template, you need separate template for excel export
Rumceisz
the excwel export will be generated from the Issue Navigator.
