Time (hh:mm) format custom field
fbeck_br
Is there any add-on for time format custom field (hh:mm) ?
ie: 05:23
So I can search for issues where timefield > 3:00.
Note: It is not related to spent work time to resolve the issue.
Jens Kisters __SeibertSolutions
May 24, 2018
Epic Sum Up has an Custom Field Time which can be used to hold Durations (e.g. 3h 14m).
It cannot format the Time as "time of the day" e.g. 16:30 though.
Radu Dumitriu
November 4, 2013
Yes. Try KCF, free. You will have SIL CF, and you need only to build a simple script.
http://confluence.kepler-rominfo.com/display/KCF/SIL+Script+Custom+Field
AlaA
November 4, 2013
Hey there,
I think this requirement was covered in the following Improvement request:
https://jira.atlassian.com/browse/JRA-29204
Please feel free to refer to the ticket for the workaround to achieve the time format for custom fields.
Let us know how it goes.
