Time spent in In progress + Open statuses -HOW TO?
Rumceisz
Hi All,
I have a problem: I need to get the time spent in In progress + Open statuses for each issue.
I made a script (scripted field) but it fails. Can you please help?
import com.atlassian.core.util.DateUtils
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.history.ChangeItemBean
def componentManager = ComponentManager.getInstance()
def changeHistoryManager = componentManager.getChangeHistoryManager()
def inProgressName = "In progress"
def onHoldName = "Open"
def rt = [0]
// Loops through every status change
changeHistoryManager.getChangeItemsForField (issue, "status").reverse().each {ChangeItemBean statusChange ->
   // Get the time passed since status change
   def timeDiff = System.currentTimeMillis() - statusChange.created.getTime()
   // If the status change left our status, we want to subtract the time passed since then
   if (statusChange.fromString == inProgressName) { rt << -timeDiff }
   if (statusChange.fromString == onHoldName) { rt << -timeDiff }
   // If the status change goes to our status, we want to add the time passed since then
   if (statusChange.toString == inProgressName) { rt << timeDiff }
   if (statusChange.toString == onHoldName) { rt << timeDiff }
// Now compute the sum of all array elements.
// Devide by 1000 to not show anything less than 60 seconds
Mizan
October 29, 2012
Try the below code . I have not tested it but modified the existing code which i found in the script runner docs. Hope it helps
def inProgressName = "In Progress"
def rt = [0]
changeHistoryManager.getChangeItemsForField (issue, "status").reverse().each {ChangeItemBean item ->
    def timeDiff = System.currentTimeMillis() - item.created.getTime()
    if (item.fromString == inProgressName) {
        rt << -timeDiff
    if (item.toString == inProgressName){
        rt << timeDiff
def inOpen = "Open"
def rt1 = [0]
    def timeDiff1 = System.currentTimeMillis() - item.created.getTime()
    if (item.fromString == inOpen) {
        rt1 << -timeDiff1
    if (item.toString == inOpen){
        rt1 << timeDiff1
DateUtils.getDurationString(Math.round(rt1.sum() / 1000)+Math.round(rt.sum() / 1000))
Rumceisz
Hi Mizan,
I tested but it failed:
javax.script.ScriptException: groovy.lang.MissingPropertyException: No such property: Open for class: Script21 A stacktrace has been logged.
Thanks for help!
Rumi
Mizan
October 30, 2012
Hi Rumi ,
I have edited the above code you can try it now.
Rumceisz
Hi Mizan,
I tested your code and I get:
javax.script.ScriptException: java.lang.NumberFormatException: For input string: "9m" A stacktrace has been logged.
It seems to me that the code sums the 'In progress' time spent but exclude the Open status. And the result ("9m") is in the warning message not in the proper custom field.
Mizan
October 31, 2012
I have edited the above script , i am not sure i think this wont give proper results ..
How about adding 2 scripted feilds (hide these 2 using behaviours plugin) one for Inprogress time and other for Open time and a 3rd field which will display the sum of these custom fields .
Chava Pemberton
June 2, 2016
Did this ever work out?
I'm having the same problem with Open status
Tansu Akdeniz
There is a Time in Status Plugin on marketplace. You can get reports depending on user, project and advanced mode. You can export the reports to excel also.
Tansu Akdeniz
ROBERT FELICIANO
August 23, 2021
Such a simple thing and Jira cannot do it? Really? After all these years adding features? Incredible.
Andrey Markelov
August 29, 2013
