Hi!
We are setting JIRA and we created a custom workflow for tickets (lets say it is analysing -> developing -> testing -> closed). We would like to see time spent (logged work) for every state of workflow in every ticket. For example I would see, that analysis took 2 days, development 3 hours etc. Is there any way, how to do this? We have Tempo plugin installed.
Is it also possible to aggregate coments by the state of the ticket? I mean I would see all coments for state Analysis on one place, then for Development below it and so on.
Thanks for any reply
try free add-on: https://marketplace.atlassian.com/plugins/ru.andreymarkelov.atlas.plugins.datacollector
It allows to do this
I checked it out, it is measuring real time elapsed, I need logged work:-) Is there any way how to set it?
For the first part of oyur question, YEs, you can with the help of jira suite utilities plugin. You get a tab - transitions on the view issue screen which tells you how much time was spent by the issue on the various workflow states.
On the second part, i do not think out of the box it is possible. Everytime a comment is made it appears under the general comments field. You may be achieve this with the help of some plugin but i am not sure on that
Rahul
Thank you for reply. Is Jira Suite Utilities showing logged work, or real elapsed time?
It shows you amount of time that the issue has spent physically in that very status of the workflow.
It has nothing to do with logged time.
If i were you, the first thing i would do is downalod an evaluation version of the plugin, put it on a test jira instance and check the feature out.
Hi, i am interested in logged work, so it is propably not what I am looking for. Thanks anyway:-)
ok got you, in that case i withdraw by suggestion. :)
