Time spent (when resolving task) isn`t required
saravicius October 17, 2013
How to make field Time spent (when resolving task) as required field?
Tamara Tchavtchavadze November 20, 2013
hey,
Sorry for the late responce.
You need to create a new screen (for example name it - Resolving Issue Screen) and add Time Tracking field. In the workflow, configure the transition (one that is used to Resolve the task) - add newlly created screen to Transition View. Then add validators - select "Field Required Validator" and in the "Field" configuration select "Time Spent".
Hope this will help.
Best wishes,
Tamara
George Mihailoff
August 20, 2018
Old question, however for those who are still looking for a better answer -- what if you don't need to log work manually at all and therefore no need to enforce it?! Check out the addon or website.
Tried... seems a bit complicated :)
Tamara Tchavtchavadze October 17, 2013
Hi Sarunas,
You can add "Time Tracking" field to Transition screen (to screen when resolving issue) and set validator "Required Field" to "Time spent"
cheers
saravicius November 3, 2013
Tamara, could you explain a bit more? I`m quite experienced user, but still I failed to do what you have advised me. Thanks.
David Skreiner
November 8, 2016
There is no such validator in vanilla JIRA 6.4.x. Either the info is outdated, or maybe an addon is required.
Richard Crampton March 28, 2017
I think this refers to extra validators that are added when you install the free plugin 'JIRA Suite Utilities'
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
