Timesheet issue after backup or upgrade JIRA.
Boris Hitev March 5, 2013
Hello, After JIRA upgrade or after importing JIRA backup I have Gadget error.
Error loading gadget from rest/gadgets/1.0/g/jira-timesheet-plugin:timesheet-gadget/gadget.xml: org.apache.shindig.gadgets.GadgetException: Unable to retrieve gadget xml. HTTP error 500
If I delete the gadget and add it again it will work. But the problem is that soon I'm going to do JIRA upgrade and I don't want to ask and explain everybody that they have to delete and add again their timesheet gadged. Is there any more convenient way to do it without being necessary to readd it again?
Boris Hitev
Vishnukumar Vasudevan
March 6, 2013
This gadget comes from JIRA Time Sheet plugin. Have you disabled/uninstalled it over the upgrade process ? I faced the same issue when I did so.
Boris Hitev March 6, 2013
Yes, I have disable it because when I did JIRA Upgrade Check the plugine "Timesheet" was in the list Compatible after upgrade the plugin also.
"These plugins have updates that are compatible with JIRA 5.2.6, but are not compatible with your current version of JIRA. To proceed with your upgrade safely, we recommend that you disable these plugins, perform the product upgrade, and then upgrade these plugins after your product upgrade is complete.
I'm still in LAB environment and I still have some snapshots where I can revert and try again without disabling the plugin. If you think it could be a solution.
March 6, 2013
Hmm, I had done the same and had to remove and add the gadgets again to get it working :(.
Please wait a while, perhaps someone else will have a better idea.
Register Now
