Hi!
I use this script to display instructions for field after hovering on question mark icon. Problem is that, icon is display under the custom field, i would like display this next to field. I'm not javascript developer and I search for some ready solution. Does anybody know how to do this?
<script type="text/javascript">
function showDaneKlienta(oEvent) {
var oDiv = document.getElementById("DaneKlientaHelp");
oDiv.style.visibility = "visible";
oDiv.style.left = oEvent.clientX + 5;
oDiv.style.top = oEvent.clientY + 5;
function hideDaneKlienta(oEvent) {
oDiv.style.visibility = "hidden";
</script>
<div id="DaneKlientaHelp1"
style="display: inline-block;"
<a href="#" onmouseover="showDaneKlienta(event)" onmouseout="hideDaneKlienta(event)";
return false;"><img src="/images/icons/ico_help.png"/></a>
</div>
<div id="DaneKlientaHelp"
style="background-color: white; position: absolute; visibility: hidden; display: inline-block; padding: 5px">
<span style="font-weight: bold">My text with instruction.</span><br />
</div>
Hi @Tomasz Bryla ,
I believe you are adding that snipped code directly on the field's description, am I right? If so, the reason is that description text is always shown in a specific div right after the field's HTML entity (select, input, etc).
If you would like to have similar result than with Estimations field (see an example as follows):
Then I suggest that you replicate same structure as done by Jira such us:
Basically adding the element A after the field you want to have it linked. For that, you will need to use some DOM modifier with JS or Jquery to add elements on the right position, etc..
Hope it helps!
