To have Due Date as Mandatory Fields
Amitava Chattopadhyay
I have a few very basic queries, but need to clear my doubts:
Problem Statement: Several projects already exist in the system without any mandatory fields such as 'effort estimation', 'start date', 'due date' to be specific and many tasks are either completed or on the verge of completion. Request your help to understand the following:
Queries:
a) I can make those fields 'Mandatory' by ticking checkbox 'Required'. However, will it affect existing issues, or it will be effective during new issue creation.
b) I want to apply it project specific only, instead of applying it at global level for all projects - what is the best practices should I follow - kindly guide.
The main objective is to have (correct information) on effort estimation.
Amitava
4 accepted
Faiz Aziz June 3, 2024
Answer :  You can make those fields 'Mandatory' by ticking checkbox 'Required'. It will not affect existing issues, however it will be effective during new issue creation.
Answer : b) You can do project specific instead of applying it at global level for all projects.
So you need to create Field Configuration and map project specific.
Manoj Gangwar
Hi @Amitava Chattopadhyay ,
I suggest you make the field required using the workflow by adding a field required validator on a particular transition.
Armitha Reddy Toorpu Ceema
June 3, 2024
I would request you to use the field required validators by using the workflow or else you can use separate screens, screen scheme and field configuration scheme to keep the field mandatory as required so that it will not effect the other projects.
NOTE:- Please do accept the answer if this helpful for you.
Armitha.
Lauren Allen
June 3, 2024
@Amitava Chattopadhyay I can highly recommend the Jira Administration Part 2 training course to help you with this.  There is a module specifically on Field Configurations and setting fields to have different behaviour in different projects and/or issue types.
If you are just using the default fild ocnfiguration for everything that may be why you are having issues.
Thank you, Is it available online or I would appreciate if you can share any link to register. Regards,
Lauren Allen
June 10, 2024
It is available via the Atlassian University as a free online course.  https://university.atlassian.com/student/path/824378-jira-administration-part-2?sid=41264f27-9cd7-4370-a764-c80957be34f2&sid_i=0
It's also available as live training with an instructor and hands on labs. This can be more effective as you have the ability to ask questions and get more contextualised advice. Not sure what your location is, but Atlassian does have a public calendar of classes around the world.  Not all providers use this feature though.
https://trello.com/b/VcNBxWCH/public-class-calendar/calendar-view
Register today
