To set assignee when issue is moved
Eshwar Palem
March 21, 2019 edited
import com.atlassian.jira.event.issue.IssueEvent;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.jira.event.type.EventDispatchOption;
Issue issue = event.getIssue();
MutableIssue mutableIssue = null;
mutableIssue = issue;
ApplicationUser user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
if(issue.getIssueType().getName().equalsIgnoreCase("Legal"))
mutableIssue.setAssignee(user);
ComponentAccessor.getIssueManager().updateIssue(user, mutableIssue, EventDispatchOption.DO_NOT_DISPATCH, false);
 The above one is my script to set the assignee when an issue is moved from one issuetype to another issuetype,the assignee should be of issuetype to which an issue is moved.
I am getting an error like "cannot an assign value of type com.atlassian.jira.issue.Issue to variable of type to com.atlassian.jira.issue.MutableIssue"
Tom Lister
Try
mutableIssue = ComponentAccessor.getIssueManager().getIssueByCurrentKey(issue.getKey);
Eshwar Palem
Hi, @Tom Lister
Now my script is with zero errors after adding the above line, thanks for that. but when I am adding this to Script listeners in Scriptrunner it is not running yet after doing the move operation. Do you have any suggestions for this like what will be the solution.
Thanks in advance.
Tom Lister
Hi
Hard to say without running it. Are there any errors in the Jira log?
can you put some logging statements in your code.
Even if it’s compiling it may be having an error retrieving the issue. Possibly getting a nullpointerexception
Eshwar Palem
Hi Tom,
I am getting this error:
groovy.lang.MissingPropertyException: No such property: event for class: Script299 at Script299.run(Script299.groovy:18).
Register now
