Hello team,
I am responsible for some projects when one of my colleagues left my organization. But my colleague creates Jira dashboards and a number of filters as the part of work, I can't able find filers and dashboards is created, at owner box his name is not reflected because his left my organization.
How to find his created filers and dashboards and how to change the owner of that filters and dashboards.
Thanks in Advance.
Thanks @Ollie Guan,
But here the problem is when clicking (select owner) I will get User picker template but here that user is not available because he is left from the organization.
Is it possible through the database?
Hi @Raju Anumula,
Even if the user is disabled, the filters and dashboard should still be queried. After you find out, you can change the Owner to yourself.
As a Jira administrator you can change filter properties:
https://confluence.atlassian.com/adminjiraserver/managing-shared-filters-938847876.html
Same for dashboards:
https://confluence.atlassian.com/adminjiraserver/managing-shared-dashboards-938847879.html
Hope this helps!
Thanks @Charly [DEISER].
