Transition a linked issue when parent/source issue performs a transition : Scriptrunner
Andrew Lonardelli
Hi everyone,
After doing some research online, and editing/adding some script I came up with a postfunction that is suppose to transition a linked issue in another project.
 When the source issue gets moved from populate to review, I want the other issue(linked issue) within another project to get moved from Display to Not Display.  This post funtion lies in the source issue transition.  Can somone help me and let me know what I need to change to make the issues transition properly. My script and the logs are displayed below:
import com.atlassian.jira.issue.link.IssueLink
import org.apache.log4j.Logger
import org.apache.log4j.Level
def log = Logger.getLogger("com.acme.CreateSubtask")
log.setLevel(Level.DEBUG)
def issueService = ComponentAccessor.getIssueService()
def linkType = ["relates to"]
// 6.x validateTransition wants a User, so we have to use getDirectoryUser()
// 7.x validateTransition wants an ApplicationUser, so remove the .getDirectoryUser() after we upgrade
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def linkMgr = ComponentAccessor.getIssueLinkManager()
// Look through the outward links
log.debug("commence for loop")
for (IssueLink link in linkMgr.getOutwardLinks(issue.id)) {
    log.debug("entered for loop")
    def destIssue = link.getDestinationObject()
    // Does the name of the link match "relates to" ?
    if (linkType.contains(link.issueLinkType.name)) {
        log.debug("relates to is the link type")
        def destStatusObject = destIssue.getStatus()
 // Is the status of the linked issue "Display" ?
        if (destStatusObject.name == "Display") {
            // Prepare our input for the transition
            log.debug("Status == Display")
            def issueInputParameters = issueService.newIssueInputParameters()
            issueInputParameters.with {
                setComment("Cancelled Vacation Request by HR")
                setSkipScreenCheck(true)
            // Validate transitioning the linked issue to "Signs Needed"
            def validationResult = issueService.validateTransition(user, destIssue.id, 61, issueInputParameters)
            if (validationResult.isValid()) {
                log.debug("Validation Result is valid")
                // Perform the transition
                def issueResult = issueService.transition(user, validationResult)
                if (! issueResult.isValid()) {
                    log.debug("Failed to transition task ${destIssue.key}, errors: ${issueResult.errorCollection}")
            } else {
                log.debug("Could not transition task ${destIssue.key}, errors: ${validationResult.errorCollection}")
        } else {
            log.debug("Skipping link: ${link.issueLinkType.name} ${destIssue.key} ${destStatusObject.name} (wrong status)")
    } else {
        log.debug("Skipping link: ${link.issueLinkType.name} ${destIssue.key} (wrong type)")
2017-07-10 14:01:48,811 DEBUG [acme.CreateSubtask]: commence for loop
2017-07-10 14:01:48,811 DEBUG [acme.CreateSubtask]: entered for loop
2017-07-10 14:01:48,812 DEBUG [acme.CreateSubtask]: relates to is the link type
2017-07-10 14:01:48,812 DEBUG [acme.CreateSubtask]: Status == Display
2017-07-10 14:01:48,851 WARN [contact.ContactSelectCF]:  ContactSelectCF getValueFromCustomFieldParams
2017-07-10 14:01:48,851 WARN [contact.ContactSelectCF]:  ContactSelectCF getValueFromCustomFieldParams singleParam 11417
2017-07-10 14:01:48,851 WARN [contact.ContactSelectCF]:  ContactSelectCF getValueFromCustomFieldParams option 11417 : Not defined
2017-07-10 14:01:48,851 WARN [contact.ContactSelectCF]: ContactSelectCF validateFromParams crm org option null for OAG-39
2017-07-10 14:01:48,851 WARN [contact.ContactSelectCF]:  ContactSelectCF :: store put Not defined : 19342_customfield_11711
Andrew Lonardelli
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
