On the actual workflow we have this trigger and some post-functions which are generating 5 types of sub-tasks.
Can I add any condition, validator or post functions to exclude this trigger rule from a project?
Let's say I have 10 projects which are using the same workflow...I want the 11th to use the same workflow but without this trigger associated to it.
Thank you,
since Conditions, validators, and permissions will be ignored for automatic transitions. Only solution is copy the workflow and remove Trigger and associate to project
That's bad :( I would like to keep that project in the same workflow.
