Transition status updated date
Aleksey Omelchenko February 26, 2015
Hi!
In Eazy BI we have measure (issue property) calles "Issue status updated date" and it looks like
[Issue].CurrentMember.get('Updated at')
Now, I'd like to get another information: the exact time when Transition status updated
Id like to get something like that
image2015-2-26 14:51:28.png
Here is the list of my actions:
1) Pick Issues as Row Dimension
2) Drill it across Measures Dimension, using Issue property "Issue status Updated Date"
3) Pick Transition Status as a Column Dimension
Here what i get instead of table needed:
image2015-2-26 15:1:52.png
It all the time shows the date of last status update no matter what transition status i pick
Could you please help me with this case?
Are there any issue property available, something like "Issue transition status Updated date"
We only started learning this complex tool and I haven't got any skill in creating my own properties via MDX query language yet.
Lauma Cīrule
February 27, 2015
Hi Aleksey,
You are correct, the 'Issue status updated date' shows the last time the status was updated.
The historic issue status changes are saved in the Transition status dimension and measures. You can group these measures, e.g. Transitions to status and Transitions from status, with Transition status and Time dimension to get total issues that transitioned to/from status during selected time period. Please see example report here https://eazybi.com/accounts/1632/cubes/Issues#report/test%20Transitions%20to%20and%20from%20status%20in%20filtered%20time
This report has aggregated issues for each time period. By clicking on each column you can select 'Drill through issue' to see which issues did the transition in the selected time period.
Please let me know if you have any additional questions!
Lauma, support@eazybi.com
Register now
