I am planning to internationalize my plugin Project Specific Select Field, which allows project admins to add option values for select lists project specific on their own (this is normally only possible for JIRA admins).
The only plugin specific text I have is "Project Specific" as the label of an additional tab in the browse project view.
Would be great if you can support me and suggest translation texts for your prefered language e.g. french, spanish, italian, japanese, chinese ect.
Many thanks for your support in advance!
Holger
I wanted to avoid automatic translations like Google translate, because they sometimes create strange things. Using it as a hint of first idea is great, but I cannot check it, because I am not familiar with spanish or french language. :-)
