×I am trying to write a query that finds all issues in a project which have no 'is parent of' links to a child issue.
The only JQL function that I have found which lets me query links for an issue is linkedIssues(key), or linkedIssues(key,type).
However I cannot make this work.
It seems that I need a Query function which works as:
getLinkQty()
or getLinkQty(type)
In both cases it would return the number of links of type that an issue has.
This would let me build a query such as:
project = LFEAT AND issuetype = HLR and getLinkQty('is parent of')!=0
Is there such a function available, or is there an alternate way to build a query in JQL which can satisfy this?
Curently using JIRA 4.1, but upgrading to JIRA 5.0 soon.
JQL Tricks plugin should do the trick. It's a paid plugin though. It looks like Search Linked Issues for JIRA will also work for you:
issue in/not in linkedIssuesFromQuery("JQL query", "relation name","direction of relation") - finds all issues which are linked by w specified relation with those found by specified query
I went with the Search Linked Issues for JIRA solution and after a bit of head scratching managed to get it to work.
Thanks for the quick answer.
Glad it worked!
Strange that this thread says "Solved" but there is no solution posted!!
