Trying to get total time in transition without weekends
Bryan_Karsh
Hi gang,
I know Jaimie has a great example of calculating total time an issue's been in a particular status:
https://scriptrunner.adaptavist.com/latest/jira/scripted-fields.html#_total_time_this_issue_has_been_in_progress
I've been trying to modify it to only count duration during weekdays (no weekends). I've seen some examples, but I can't get my version to work. I feel like I am close, but missing something. Can someone take a look at my script, and suggest what I need to change? Thanks!!
PS – if someone has a way to use jiraDurationUtils to parse the duration to keep out weekends. that would be good to know. Wasn't successful via that approach either.
import static java.util.GregorianCalendar.*
import com.atlassian.jira.issue.history.ChangeItemBean
enableCache = { -> false }
def changeHistoryManager = ComponentAccessor.getChangeHistoryManager()
def myStatus = "In Progress"
List<Long> rt = [0L]
def changeItems = changeHistoryManager.getChangeItemsForField(issue, "status")
changeItems.reverse().each { ChangeItemBean item ->
    item.toString == myStatus
    def timeStart = System.currentTimeMillis()
    def timeEnd = item.created.getTime()
    def c1 = new GregorianCalendar()
    c1.setTimeInMillis(timeStart)
    int w1 = c1.get(DAY_OF_WEEK);
    c1.add(DAY_OF_WEEK, -w1);
    def c2 = new GregorianCalendar()
    c2.setTimeInMillis(timeEnd)
    int w2 = c2.get(DAY_OF_WEEK);
    c2.add(DAY_OF_WEEK, -w2);
    //end Saturday to start Saturday
    def days = (c2.getTimeInMillis() - c1.getTimeInMillis()) / (1000 * 60 * 60 * 24) as long
    def daysWithoutWeekendDays = days - (days * 2 / 7) as long
    // Adjust days to add on (w2) and days to subtract (w1) so that Saturday
    // and Sunday are not included
    if (w1 == SUNDAY && w2 != SATURDAY) {
        w1 = MONDAY;
    } else if (w1 == SATURDAY && w2 != SUNDAY) {
        w1 = FRIDAY;
    if (w2 == SUNDAY) {
        w2 = MONDAY;
    } else if (w2 == SATURDAY) {
        w2 = FRIDAY;
    //convert to seconds for Duration
    def timeDiff = (daysWithoutWeekendDays - w1 + w2) * (60 * 60 * 24)
    // def timeDiff = timeStart - timeEnd
    if (item.fromString == myStatus) {
        rt << -timeDiff
    if (item.toString == myStatus) {
        rt << timeDiff
def total = rt.sum() as Long
return total ?: 0L
Sanjay Dhandare
January 16, 2020 edited
//After working and troubleshooting I came up with the solution which gives actual time excluding weekend (Saturday and Sunday)
import java.util.concurrent.TimeUnit
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.bc.issue.IssueService.UpdateValidationResult
import com.atlassian.jira.bc.issue.IssueService.IssueResult
import com.atlassian.jira.issue.IssueInputParameters
import com.atlassian.jira.issue.changehistory.ChangeHistoryManager
import com.atlassian.core.util.DateUtils
def statusCode = ['Done','In Progress','In testing','In Implementation','To Do'];
IssueManager im = ComponentAccessor.getIssueManager()
//MutableIssue issue = im.getIssueObject('TES-24')  // Uncomment for troubleshoot in console
ChangeHistoryManager changeHistoryManager = ComponentAccessor.getChangeHistoryManager()
String myStatus = "In Progress"   // can be taken dynamically ->  issue.getStatus.name
long curTime = System.currentTimeMillis();
changeHistoryManager.getChangeItemsForField(issue, "status").reverse().each { ChangeItemBean item ->
Calendar c1 = new GregorianCalendar()
c1.setTimeInMillis(item.created.getTime())
int iHolydayCnt = 0;
while(c1.getTimeInMillis() < curTime)
c1.add(Calendar.DAY_OF_YEAR, 1)
if((c1.get(Calendar.DAY_OF_WEEK).equals(Calendar.SATURDAY)) || c1.get(Calendar.DAY_OF_WEEK).equals(Calendar.SUNDAY) )
++iHolydayCnt;
//log.warn(iHolydayCnt)
long timeDiff = curTime - item.created.getTime() - iHolydayCnt*(60*60*24*1000)
rt << -timeDiff
rt << timeDiff
def total = rt.sum()/1000 as Long
def mytotal =DateUtils.getDurationString(total)
log.warn(total)
log.warn(mytotal)
return mytotal ?: 0L
// Happy Coding // Sanjay_D_D_Programmer
Madhusudan Bhosale
Thanks buddy..
It helped me a lot !
Like Sanjay Dhandare likes this
Kunal Saraf January 16, 2020
Well done buddy..
works really great to get the actual time excluding weekends.
Sanjay Dhandare
Thanks Kunal for acknowledging !
Zaldy Parian
May 17, 2020
@Madhusudan Bhosale
Can you please give me the steps to get this implemented in our Jira Cloud?
Appreciate it very much.
Zaldy
Vasiliy Zverev
January 25, 2017
Try this one to find holydays count:
List&lt;Long&gt; rt = [0L]
changeHistoryManager.getChangeItemsForField(issue, "status").reverse().each { ChangeItemBean item -&gt;
    while(c1.getTimeInMillis() &lt; curTime){
        if((c1.get(Calendar.DAY_OF_WEEK) == Calendar.SATURDAY) || (c1.get(Calendar.SUNDAY)) )
            ++iHolydayCnt;
        rt &lt;&lt; -timeDiff
        rt &lt;&lt; timeDiff
return total ?: 0L
Sanjay Dhandare
Thanks buddy Your scripts helped me a lot but need some minor correction which i did you can refer above.
Chhaya Gadade January 22, 2020
Hi @Vasiliy Zverev ,
   Is this script working for initial statuses,e.g Open Or To Do like that?,in my case it is working for remaining statuses rather than initial status i.e.Open or To Do,can you please help me.
Register now
