Tutorial for script runner
Paul DeSousa
October 13, 2014
Anyone know where to find a tutorial on script runner?  It looks like exactly what we need but being new to JIRA.
8 votes
Alejo Villarrubia [Adaptavist]
July 10, 2015
kunti pawar May 7, 2018
now I am opening above link, but page does not exist, anybody can help me?
Nic Brough -Adaptavist-
May 8, 2018
It's nearly 3 years old, and people have moved on.  Have a look at the SR docs and search this community for what you're trying to achieve.
kunti pawar May 8, 2018
Hi Nic Brough ,
Thanks for reply,
Now I am able to looking script runner in jira.
But I need help for the retrieve issue id using scriptrunner
Could you please help me when you get free time
May 9, 2018
How you retrieve an issue id depends on where you are running the script.  If it's in the console, you'll need to use an issueManager to fetch the issue.  If you're in a transition then the object simply called issue is immediately available to your scripts, and so-on.
Like Manga Man likes this
Dennis Alexander June 6, 2019
so is there any document that outlines this?
June 6, 2019
https://scriptrunner.adaptavist.com/latest/index.html will take you to the relevant docs
Like senthilkumar sellakani likes this
Look
https://scriptrunner.adaptavist.com/latest/jira/scripted-fields.html#_scripting
https://scriptrunner.adaptavist.com/latest/jira/builtin-scripts.html#_technical_stuff_for_advanced_users
see a couple of bindings (quick starting points) could be used in different scenarios
It would be nice to have a table of what bindings I can use in different scenarios
Console these bindings
Built-in scripts: these bindings
Transition scripts: these bindings
Scripted fields: these and so on
It's kind of painful to learn from other people scripts and mostly it's a guesswork
For example, Scripted Fields does not mention that issue is available as a binding. Perhaps it is obvious, but a clear map of what binding(shortcuts) are available where would be probably the most popular page on Adaptavist web site.
Paul DeSousa
October 13, 2014
Thanks Michal, but I was looking for something a bit more basic (Start me with a hello world :). Being new to JIRA, I do not even know where to start. I started writing plugin but that will take some time and to solve the immediate need of having a script that will automatically put the project into the correct component. Cheers...
Paul DeSousa
October 13, 2014
When I try to run any example I get every line as an error: Error!startup failed: Script1.groovy: 1: unable to resolve class ComponentManager @ line 1, column 18. ComponentManager componentManager = ComponentManager.getInstance() ^ Script1.groovy: 2: unable to resolve class User @ line 2, column 6. User remoteUser = componentManager.getJiraAuthenticationContext().getUser() ^ Script1.groovy: 3: unable to resolve class MutableIssue @ line 3, column 14. MutableIssue issue = componentManager.getIssueManager().getIssueObject("DTT-1757") ^ Script1.groovy: 4: unable to resolve class Project @ line 4, column 9. Project project = issue.getProjectObject() ^ Script1.groovy: 5: unable to resolve class Version @ line 5, column 9. Version version = componentManager.getVersionManager().getVersion(project.getId(), "1.2") ^ Script1.groovy: 6: unable to resolve class ProjectComponent @ line 6, column 18. ProjectComponent component = componentManager.getProjectComponentManager().findByComponentName(project.getId(), "MyComponent") ^ Script1.groovy: 11: unable to resolve class ActionResult @ line 11, column 14. ActionResult aResult = CoreFactory.getActionDispatcher().execute(ActionNames.ISSUE_UPDATE, actionParams); ^ 7 errors
JamieA
October 13, 2014
Are you trying to do this in confluence, or was that just a "tagging failure"?
JamieA
October 13, 2014
Assuming you did mean jira, seems like you are missing an import: import com.atlassian.jira.ComponentManager
Paul DeSousa
October 13, 2014
Thanks Jamie, and yeah I am doing 100 things on both JIRA and confluence. This is a JIRA thing, apologies. OK yeah that is why I really would like a how to like the develop your own plugins. Thanks I will try that (tomorrow as it is late in the East :)
Paul DeSousa
October 14, 2014
OK That fixed the first line error, I probably just need more imports as I just copy pasted: https://jamieechlin.atlassian.net/wiki/display/GRV/Post+Functions#PostFunctions-SetAffectsVersions,FixVersionsorComponents which has no imports. It may help users if you post the imports in that block of code just like the other ones have. Just my two cents...
Daniel Luevano
@Paul DeSousa Did you find that tutorial? I would be really useful this time for me, thanks!
Register here ⬇️
