Two Dimensional Filter Statistics - Missing Affected Version field
EdG July 3, 2013
I am running JIRA 5.2.11 and I am attempting to harness our Affected Version (x) and custom field Fix Priority (y) to generate statistics using a Two Dimentional Filter Statistics Gadget on our Dashboard. Fix priority shows up in the options of the gadget , but not Affected Version. Other non custom fields, such as Fixed Version, show up as an option.
Background Research:
Based on https://answers.atlassian.com/questions/16001/remaining-estimates-not-available-in-two-dimensional-filter-statistics, I should reindex.
Other thoughts?
4 votes
Justin Alex Paramanandan
July 3, 2013
I believe the Affect Version/s field is bounded to the Raised in Versions field in the two-dimensional filter configuration:
I have an issue with the following:
  • Affect Version/s: Version 1
  • Fix Version/s: Version 2
Once I configured the above, I got this:
So, why not you try this and see whether it works for you?
Also, might as well configure the columns in the Issue Navigator to include the affect and fix versions.
EdG July 4, 2013
Thanks Justin!
Vedant Kulkarni
There is a feature request for renaming it to Affect Version https://jira.atlassian.com/browse/JRASERVER-41573
