I would like to create a new priority field that is automatically calculated from two other single dropdown fields or a single cascading dropdown field (whichever is easier). The two factors would be below Frequency (4 options) and impact (12 options), and based on those inputs the new priority would be calculated.
Is this possible using Script Runner?
Hi Bryan,
Taking Gabrielle and Doug's comments a little further, the code you'll want will look something like this:
def frequency = getCustomFieldValue("Frequency").getValue() def impact = getCustomFieldValue("Impact").getValue() if (frequency && impact) { switch (frequency) { case "First Frequency": switch (impact) { case "First Impact": return "something" case [...] } case [...] } }
Obviously, replacing the switch/case statements with whatever logic you're after (I include those as a simplistic example). If you have any other questions, please post here.
Hi Jamie, Thank you so much for the information. This is very helpful. I used your Query in the inline script field for the "True Priority" Script field. I am not able to return anything. The "True Priority" field doesn't even show on the issue even though it has been added to the screen. Here is the Query I am using, for only one case to test. def frequency = getCustomFieldValue("Frequency").getValue() def impact = getCustomFieldValue("Impact").getValue() if (frequency && impact) { switch (frequency) { case "Always": switch (impact) { case "Security: In Production": return "P1" } }
As Gabriella said - Yes this is possible with a Script Runner scripted field. We do something very similar.
