Two dimentional filter gadget reflects data out of order?
Alexis_Pruitt
The order of the status in the Agile gadget on our dashboard appears to be out of order.
We would expect it to reflect in order:
To Do
In Progress
Resolved
Closed.
Instead it shows:
In Progress
Resolved
Closed
To Do
We have verified the board columns are in the proper order of:
To Do
In Progress
Resolved
Closed
Can anyone explain how/if we can change this?  It doesn't make sense to have the "To Do" as the last column.
We are running Jira Server v.7.6.2.
Nic Brough -Adaptavist-
January 31, 2018
The gadget has no way of guessing what your workflow might be, let alone any boards, it's simply been handed data with a load of status in it.
My best guess is that it's sorting them by the order they were added to your Jira - I suspect if you look at the ids that are behind them, you'll find In progress has an id like 10020, then Resolved 10030, Closed 10050, and To Do 10090 - the counter goes up every time a new status is created, so higher numbers = newer.
Alexis_Pruitt
Got it.  Thanks.  I suspect this will prove true when I delve in to take a peek.
Thanks so much!
Learn more
