I am in the process of migrating our Mantis issue database (v2.12.0) into Jira Server (v8.3.3), but the import is failing on every attempt. Both Mantis and Jira are running on PostGres. The error seems to occur during the Component import step and is caused by some sort of type mismatch, but no information is given as to what is actually causing the error. This error results in no issues being created for the project. I have been unable to find any info on this error online, so hopefully someone can provide some help with this as it is blocking our transition to Jira.
The full error log is as follows (with project/user names replaced):
2019-09-13 15:03:23,408 INFO - Import started by user using com.atlassian.jira.plugins.importer.imports.mantis.MantisDataBean 2019-09-13 15:03:23,411 INFO - ------------------------------ 2019-09-13 15:03:23,411 INFO - Importing: Users 2019-09-13 15:03:23,411 INFO - ------------------------------ 2019-09-13 15:03:23,411 INFO - Only new items will be imported 2019-09-13 15:03:23,451 INFO - 78 users associated with import. All of them imported as inactive, this can be changed after import in User Access step. 2019-09-13 15:03:23,451 INFO - ------------------------------ 2019-09-13 15:03:23,451 INFO - Finished Importing : Users 2019-09-13 15:03:23,451 INFO - ------------------------------ 2019-09-13 15:03:23,451 INFO - 0 users successfully created. 2019-09-13 15:03:23,451 INFO - Retrieving projects... 2019-09-13 15:03:23,451 INFO - Project ExternalProject{id='31', key='TES', externalName='Test', name='Test'} exists and found correctly. 2019-09-13 15:03:23,467 INFO - ------------------------------ 2019-09-13 15:03:23,467 INFO - Importing: Versions 2019-09-13 15:03:23,467 INFO - ------------------------------ 2019-09-13 15:03:23,467 INFO - Only new items will be imported 2019-09-13 15:03:23,474 INFO - Importing version 1.0 2019-09-13 15:03:23,477 INFO - ------------------------------ 2019-09-13 15:03:23,477 INFO - Finished Importing : Versions 2019-09-13 15:03:23,477 INFO - ------------------------------ 2019-09-13 15:03:23,477 INFO - ------------------------------ 2019-09-13 15:03:23,477 INFO - Importing: Components 2019-09-13 15:03:23,477 INFO - ------------------------------ 2019-09-13 15:03:23,477 INFO - Only new items will be imported 2019-09-13 15:03:23,480 ERROR - Unexpected failure occurred. Importer will stop immediately. Data may be in an unstable state com.atlassian.jira.plugins.importer.SQLRuntimeException: ERROR: operator does not exist: boolean = integer Hint: No operator matches the given name and argument type(s). You might need to add explicit type casts. Position: 213 at com.atlassian.jira.plugins.importer.web.JdbcConnection.queryDb(JdbcConnection.java:187) at com.atlassian.jira.plugins.importer.web.JdbcConnection.queryDb(JdbcConnection.java:150) at com.atlassian.jira.plugins.importer.imports.mantis.MantisDataBean.getComponents(MantisDataBean.java:92) at com.atlassian.jira.plugins.importer.imports.importer.impl.DefaultJiraDataImporter.importComponents(DefaultJiraDataImporter.java:721) at com.atlassian.jira.plugins.importer.imports.importer.impl.DefaultJiraDataImporter.doImport(DefaultJiraDataImporter.java:374) at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:26) at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:15) at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:537) at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:495) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at com.atlassian.jira.task.ForkedThreadExecutor$ForkedRunnableDecorator.run(ForkedThreadExecutor.java:216) at java.lang.Thread.run(Thread.java:748) Caused by: org.postgresql.util.PSQLException: ERROR: operator does not exist: boolean = integer Hint: No operator matches the given name and argument type(s). You might need to add explicit type casts. Position: 213 at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2455) at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2155) at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:288) at org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:430) at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:356) at org.postgresql.jdbc.PgPreparedStatement.executeWithFlags(PgPreparedStatement.java:168) at org.postgresql.jdbc.PgPreparedStatement.executeQuery(PgPreparedStatement.java:116) at com.atlassian.jira.plugins.importer.web.JdbcConnection.queryDb(JdbcConnection.java:167) ... 13 more 2019-09-13 15:03:23,481 INFO - No issues need to be reindexed.
Any help is greatly appreciated.
After a lot of digging I managed to solve this so I'm going to leave the solution here for anyone else who has the same issue.
What I discovered is that at some point between Mantis 1.2.0 and 2.23 the database schema was updated and a couple table columns were converted to booleans from integers (more info on the mantis db schemas can be found here and here). The specific column that caused the problem was `mantis_project_table.inherit_global`. The importer plugin wanted the value to be a an integer, but as the database was newer it was in fact a boolean. As a side note the error provided in the log is rather confusing as the order of the types seems to be backwards compared to what you would expect.
The fix was relatively easy, I simply made a copy of the database to use for importing and ran the following commands to convert the database to the correct format:
ALTER TABLE mantis_project_table ALTER COLUMN inherit_global DROP DEFAULT;
ALTER TABLE mantis_project_table ALTER COLUMN inherit_global TYPE integer USING CASE WHEN inherit_global=TRUE THEN 1 ELSE 0 END;
ALTER TABLE mantis_project_table ALTER COLUMN inherit_global SET DEFAULT 0;
This fixed the issue and allowed me to successfully import the mantis data.
Register today
