URL encoding in description/comment field
Deleted user July 23, 2014
I want to paste some code(incl url/links) with highlighting ({code}) into description field, so an other colleague can simply copy / paste the code to work with it.
The problem here is, that jira always adds a <a href.. in front of the URL, so the person who copys the code will always get compile errors.
So
What I do is:
{code}
some useful php code and https://www.atlassian.com/<br< a="">>{code}
What I expect to see in the description field/comment field:
What I actually get is:
some useful php code and <a href="https://www.atlassian.com/">https://www.atlassian.com/</a>
Ths is really annoying..I want a code block, I want that syntax highlighting but I do not want to have this <a href piece...
Thats should not be rocket science..?
Alexey_Rjeutski__Polontech_
August 14, 2014
I have strong feeling that jeditor replaces that link...
Deleted user August 14, 2014
Deactivated jEditor plugin and now it works...
Right feeling... Thanks a lot!
August 14, 2014
No problem) You can mark the question as answered to close it.
JIRA v6.1.7
August 14, 2014
Please try {noformat} test linking http://www.atlassian.com{noformat}
August 14, 2014
Hi, I've just checked on my local jira:
{code:xml}
<test>
<another tag="http://www.atlassian.com"/>
</test>
{code}
and that worked fine. could you please give the example that fails?
Hi Alexey,
when we use {noformat}, we dont have any code highlighting within this section, which is important for us to show that this is a code block and not plain text
Your example does not work for me. Wenn I copy your example and paste it as a comment, it looks like this:
<test>
<another tag="<a href="http://www.atlassian.com">http://www.atlassian.com</a>"/>
</test>
I dont want that
I am using the Wiki Renderer and thats why it pastes this <a href ... code block.
As soon as I set the Default Renderer, it works. But then you cannot use any of the code formatting tools which atlassian provides (bold, table, background color, etc.)...
August 14, 2014
seems you use default text renderer for your comments,
could you please try to open the field configuration (from here /secure/admin/ViewFieldLayouts.jspa) , open configuration to edit, find the comment field, and follow Renderers link, select Wiki renderer and try again.
August 14, 2014
What version of jira do you use?
JIRA v6.1.7
August 14, 2014
- I've tried on 6.1.7 with provided option - and that worked fine. The same for description. Could you please share the rendered comment / description image? and also the screenshot of it in edit mode?
Writing..
The Comment rendered
August 14, 2014
1. Please add a screenshot with the list of listeners on your system (Administration - system - listeners)
2. Please show the list of renderers for the comment field inside configuration (with screenshot)
Cant find the first thing you mentioned with the list of listeners, but this may help:
August 14, 2014
/secure/admin/ViewListeners!default.jspa - there is the list of listeners. That screenshot didn't help.
August 14, 2014
could you please try to disable jeditor plugin for a moment, check the comment creation and enable it back?
Help us plant more trees
