URL must not point to localhost or restricted IPs
Petr AST
Dear community!
How can I merge Confluence and Jira via Application links, which are on the same server? There is no way to configure, as it gives the following error: URL must not point to localhost or restricted IPs.
I followed the instructions (https://confluence.atlassian.com/jirakb/application-link-configuration-from-jira-to-confluence-fails-with-url-must-not-point-to-localhost-or-restricted-ips-1358171668.html) for adding the Java parameter to both Jira and Confluence, but this only helped for Jira - on the Confluence side, it still gives a localhost error.
-Dapplinks.allow.all.hosts=true
Maybe there are other ways or there might be errors somewhere?
Thanks in advance!
Brant Schroeder
@Petr AST are you hosted on Linux or windows?
Petr AST
@Brant Schroeder Hi Brant!
Windows
Brant Schroeder
Are you running the applications on different ports?  Are you using a proxy?
Petr AST
@Brant Schroeder
Sure, default ports - 8080, 8090
The proxy is standard, I didn't change anything
Brant Schroeder
@Petr AST How are you starting the windows applications bat file or windows service?
Petr AST
@Brant Schroeder Hi Brant, Windows service
Brant Schroeder
Did you add -Dapplinks.allow.all.hosts=true to both application services or just Jira?
