I have a report that has "logged by" in the rows, and "hours spent with sub-tasks", "project", and "issue type" in the columns. "logged by" is also in the pages section, as is the "time" dimension.
I would like to be able to see the individual worklogs for each person that make up the total in each cell, but don't see a "drill through worklogs" option. Why is the option not available/what are the conditions for it to be possible to drill through worklogs?
Thank you!
Anja
You may have to bring the "issues" dimensions under rows below "logged by" to drill through/into.
Regards
Hi did you solved. I'm trying but it doesn't work:
ROWS:
LOGGED BY
ISSUES
but I can not see the Drill through worklogs option if I right click on Hour Spent
Tullio
