Unable to Execute any transition in Jira
Renuka Patil September 24, 2012
Our client is not able to do any transition in Jira 4.3.2. Please find the attached screenshot ^unable to execute transition.png for the error. Client is getting same error since 2-3 days.
On their system following Plugins are installed :
1. Behaviours-0.4.7.jar
2. groovy-all-1.7.10.jar
3. groovyrunner-1.7.14.jar
4. jira-enhancer-plugin-2.1.1-SNAPSHOT.jar
5. jira-suite-utilities-1.0.1.jar
6. jfs-1.4.3_43.jar
Following is the log file extract :
{noformat}
2012-09-25 09:28:23,826 http-8081-2 ERROR equest 568x698x1 q5msyq 192.168.50.161 /rest/com.onresolve.jira.plugin.Behaviours/1.0/behaviours/runvalidator.json onresolve.jira.groovy.GroovyScriptLoader Class or file does not exist at this location
Sep 25, 2012 9:28:23 AM com.sun.jersey.server.impl.application.WebApplicationImpl onException
SEVERE: Internal server error
java.lang.Exception: Class or file does not exist at this location
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at org.codehaus.groovy.reflection.CachedConstructor.invoke(CachedConstructor.java:77)
at org.codehaus.groovy.runtime.callsite.ConstructorSite$ConstructorSiteNoUnwrapNoCoerce.callConstructor(ConstructorSite.java:102)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callConstructor(AbstractCallSite.java:198)
at com.onresolve.jira.groovy.GroovyScriptLoader.getScript(GroovyScriptLoader.groovy:70)
at com.onresolve.jira.groovy.GroovyScriptLoader$getScript.call(Unknown Source)
at com.onresolve.jira.groovy.BehaviourManagerImpl$_runValidator_closure5.doCall(BehaviourManagerImpl.groovy:133)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90)
at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233)
at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:273)
at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:886)
at groovy.lang.Closure.call(Closure.java:282)
at groovy.lang.Closure.call(Closure.java:295)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:1220)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:1196)
at org.codehaus.groovy.runtime.dgm$116.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:270)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:52)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:124)
at com.onresolve.jira.groovy.BehaviourManagerImpl.runValidator(BehaviourManagerImpl.groovy:121)
{noformat}
Can you please highlight which Plugin is creating the above error? Why that error is coming?
I will try to attach xml backup backup if needed at the earliest.
Thanks & Regards,
Renuka
JamieA
September 24, 2012
Disable the behaviours plugin and work out what the problem is with it in a dev/test instance.
Hi Jamie,
Thanks for the answer
I have disabled the Behaviour Plugin & Checked, I am able to do the transition. But Our Client need Behaviour Plugin. It is important for them.
Can you please suggest workaround for it ? Is it the compatibility issue?? Which version of Behaviours Plugin should I use for the same?
Thanks & Regards,
Renu
Hi Jamie,
Now I am getting following exception in catalina.out file :-
Sep 25, 2012 11:17:02 AM com.sun.jersey.server.impl.application.WebApplicationImpl onException
com.atlassian.upm.pac.PacClientConnectionException: com.sun.jersey.api.client.ClientHandlerException: java.net.UnknownHostException: plugins.atlassian.com
        at com.atlassian.upm.pac.PacClientImpl.getUpgrades(PacClientImpl.java:96)
        at com.atlassian.upm.rest.resources.UpgradesResource.get(UpgradesResource.java:35)
Can you please tell me why this error is coming & from Where it is coming??
Thanks & Regards,
Renu
Hi Jamie,
Whenever I am disabling Behaviours Plugin, It is working fine. But whenever I am enabling it again I am getting same error as above.
I am not getting why this is happening because on the other test env I am using same version of behaviors plugin there I am not getting such error. On that env. it is working fine.
Can you please explain me what is the problem ?? Why this error is coming??
Thanks & Regards,
Renu
JamieA
September 24, 2012
Looks like a problem with one of your validators perhaps. Check them... Is that the latest version of the plugin compatible with your jira version?
Renuka Patil September 25, 2012
Yes it is latest version which is compatible with my Jira. I am using Jira 4.3.2 & Behaviour version is 0.4.7. Actually same version I am using on other test env. for same jira version, It is working fine.
I am not getting what the problem is with behaviours plugin.
Shall I reinstall & check??
Thanks & Regards,
Renu
Renuka Patil September 26, 2012
Hi Jamie,
Thanks for the answer!!!
I have reinstalled Behaviours Plugin & deleted all the behaviours & added again. Now I am able to do transitions properly
Register today
